cutting stock bars
9 replies to this topic
  • The Hopper Show
Posted March 24, 2011 - 11:52 PM
do you guys cut your stock bars, or just replace em? this '05 i just picked up still has the stock renthal bars, which are in perfect shape. they just seem soo wide to me. end to end with acerbis hand guards measures 33". so about what? 31" on the stock bars? i am considering hacking up to an inch off each side. is there an easy way to test this before i cut the end off? can i move everything in an inch and go for a ride and see how it feels? or am i going to run into issues with the throttle tube doing that? will the handguards still fit if i cut them?
:thumbsup:
  • infamy
Posted March 25, 2011 - 12:14 AM
the throttle on my bike has a closed end so it wouldnt be possible. just cut them and let us know how it goes :thumbsup:
  • wrdr-rider
Posted March 25, 2011 - 02:44 AM
I needed to cut the end off of the throttle tube for the hand guards to fit, so doing that first and testing width should be fine.
I cut about 3/4" off each end of my stock bars with a hack saw. I originally tried a pipe cutter (plumbing type for copper water lines) and that was going to take forever. Even with a good hack saw, it was more effort than I anticipated.
  • YamaLink
Posted March 25, 2011 - 05:55 AM
I'd go 1/4" each side first, and then smooth out the area which was cut, inside and outside the bar.
  • woods-rider
Posted March 25, 2011 - 09:37 AM
I think cutting them down up to an inch won't be a problem.
  • cherrypicker7
Posted March 25, 2011 - 02:06 PM
I'm running some Enduro Engineering bark busters, and if I cut the bars down I would also have to modify the barkbusters as the inboard handlebar clamps can't go in much further. Year ago we used to run 30" bars.
  • The Hopper Show
Posted March 25, 2011 - 04:30 PM
would a "woods" bend bar suit me better? how is the bend compared to stock? i feel like they need to be taller/narrower/and pushed forward just a bit though i am sure i can rotate the stock ones forward to accomplish that part.
  • gsa102
Posted March 27, 2011 - 09:00 AM
I got a pair of tusk handlebar risers from ebay for about $20 and love them. You could try that for a small investment. I also used a big tubing cutter to cut 3/4" off of each bar end. My Acerbis handguards are pretty crowded, though.
  • MaxPower
Posted March 28, 2011 - 05:02 PM
[COLOR="Green"]Becareful not to cut too much off the ends of the bars.
Move your perches in as far as they go first. If you go too far the perches will have to be mounted on the bends of the bars.
If you need them narrow, you can mount mini bars
[/COLOR]
  • The Hopper Show
Posted March 28, 2011 - 05:13 PM
what is different about mini bars?
