2001 YZ426 wont kick over after top end rebuild
3 replies to this topic
  • moon55
Posted March 24, 2011 - 07:10 PM
I put a new top end in my 2001 YZ426, including new (stock) piston, rings, etc. I also had new valves, springs, guides and such put in the head. I've timed the engine according to the manual. "E" is at 9:00 on exhaust cam and "I" is at 3:00 on intake came. The cam lobes are facing away from each other and the timing mark is lined up on the flywheel. The cam caps have been torqued to the proper spec and everything appears to be ok.
When I attempt to kick the bike, I get about half a stroke and then the kickstarter will not kick through. The timing mark on the flywheel is very close to being lined up and the piston appears to be at TDC. However, the exhaust cam lobes are pushing down on the lifters and wont rotate through. :thumbsup:
What am I doing wrong in order to get this condition. Like I said, the timing initially appears to be good.
Any advice would be greatly appreciated.
Posted March 25, 2011 - 07:38 AM
Let me ask you a really silly question, OK? If you pull the compression release, will the kick starter turn the engine freely?
  • moon55
Posted March 25, 2011 - 01:37 PM
OOPS:blush: Apparently, I was distracted when assembling the piston/cylinder and I put the piston in backwards. Even though I was positive I had it in correctly.
Thanks for taking the time to reply.
Posted March 25, 2011 - 01:58 PM
OOPS:blush: Apparently, I ...put the piston in backwards.
Hopefully, the valves will have survived this little boo-boo. Solvent test to be sure they haven't been bent.
  • Hot  491 replies
  • 5 replies
  • Hot  33 replies
