2011 Yz450f?
10 replies to this topic
  • powers450f
Posted March 24, 2011 - 02:18 PM
To the people that own the 2010 or 2011 yz450f's. After break in do you check the valve clearances? Just wondering because I bought a 2011 new and was wondering if anyone had to shim them after the break in? I haven't had the chance to break mine in yet because it's 30 degrees outside, but I figured after the break in I would change the oil and filter but it says in the manual to check the valve clearances, kind of thinking that if it is brand new that it isn't necessary.. I would appreciate the feedback. Thanks
  • woods-rider
Posted March 24, 2011 - 02:25 PM
Its not hard to check and proper clearances are pretty important. If I were you I would take the 30 min to protect your multi-thousand dollar investment.
  • powers450f
Posted March 24, 2011 - 02:31 PM
Yeah I know it's not hard, but just wondering how common it is that they actually need to be shimmed? I know from the factory they are set as close to the bottom of the spec for noise and performance reasons.
  • heezay
Posted March 24, 2011 - 02:34 PM
Haven't checked mine, im sure someone on here will say im an idiot for not checking them, but oh well, not really worried about it at all.
  • Steel Panther
Posted March 24, 2011 - 02:59 PM
Ive never heard of yamaha valves needing to be adjusted after the break in, I would not be happy if my brand new bike needed a shimming.
Posted March 24, 2011 - 03:12 PM
It's not really uncommon to hear about them needing to be tweaked a little following break in. There seemed to have been quite a few '07 models that ended up with an intake or two at .09mm on the first check up and were fine ever after that.
  • powers450f
Posted March 24, 2011 - 03:31 PM
Ok think I'll check them just to be on the safe side.
  • mediumfast
Posted April 08, 2011 - 08:06 PM
It's also good to have a reference point for future valve checks.
  • brentn
Posted April 09, 2011 - 12:42 PM
Check them right after break in, like others have said it offers a good reference point for future checks.
Valve checks on the 2010/11 are really really easy to do, and take only about 15 minutes. Lifting and supporting the tank you can then remove the small black plastic head cover (push two pins in and lift out). Remove the plug boot and then remove the valve cover and that's it.
I checked my valves after 22 hours and there appeared to be no movement at all.
  • powers450f
Posted April 09, 2011 - 06:48 PM
Checked them after break in an they were perfect.
  • lil-717
Posted April 10, 2011 - 02:49 AM
40 hours hard riding and racing and no movement
  • On Yesterday, 06:20 PM
  • Hot  47 replies
  • 10 replies
  • Hot  113 replies
