SRC Foot Peg Shims
1 reply to this topic
  • AZ Thumpdaddy
Posted August 06, 2003 - 05:21 PM
Hey All,
Just to report - I installed the SRC foot peg shims on my piglet and they fit nicely. They are eyelets with a flare that go over the bolts and take up the tolerance slack between the bolts and the right foot peg. They are pricey but should be worth it from www.srcinc.net . -----
XR-650R Foot Peg Bolt Shim Kit
The XR-650R is known for breaking the right foot peg bolts. Our analysis of the cause and cure are described in our technical bulletin on the subject. The simple solution, before premanent damage is done to the frame, are these simple to install shims that reduce clearance between the foot peg bracket holes and bolts.
XR-650R Foot Peg Bolt Shim Kit Part # 1686 Price $28.95
  • Rokatt88
Posted August 07, 2003 - 05:19 AM
I'll have to check 'em out next we go ridin' Brudda! :)
