Can't figure this one out!
7 replies to this topic
  • firemanmatt82
Posted March 20, 2011 - 05:40 PM
I have an 01 YZ426. I'm installing a new chainand gears in it. However, I can't seem to get the drive sprocket off. One of my reasons is I can't figure out what size the nut is that holds the sprocket on. 2nd, Is it a reverse thread nut or is it the old "lefty loosy, righty tighty" kind of nut. Thanks for any help you can provide.:thumbsup::worthy::bonk::worthy:
  • ttr250dude
Posted March 20, 2011 - 06:50 PM
It's the standard lefty loosey righty tighty. Youre gonna have to hold your rear brake pedal down so the bolt doesnt just spin. Measure the nut with a tape measure or use a micrometer. If the micrometer reads something like 1.21" get a 1 1/4" wrench.
  • brentn
Posted March 20, 2011 - 07:38 PM
The rear brake pedal trick worked for me, I used a long pole to engage the brake with my left hand. Then using my right hand, a breaker bar and a socket, gave the CS nut a good sudden jerk to the left and it came loose.
  • gscx
Posted March 20, 2011 - 07:44 PM
You do know that you have to bend back the lockwasher that is holding the nut on right? That might help you with not knowing what size nut it is
  • ttr250dude
Posted March 20, 2011 - 07:52 PM
haha yeah that too. Just bend it with a flat head screwdriver and hammer.
  • jcm3
Posted March 20, 2011 - 08:02 PM
Yeah, I just swapped out the chain and sprockets out on my 2001 yz426, and when I got the lock washer off, the bolt came off with my hand. :thumbsup:
I used the same process that I used for my flywheel to torque the drive sprocket bolt, which was to put the bike in 5th gear and lock the rear wheel with a 2x4 through the spokes.
To take it off, an impact gun would work just fine, if you have one.
  • brentn
Posted March 21, 2011 - 01:12 PM
Electric impact guns are getting pretty cheap these days. Just picked up a mastercraft with 220ft lbs of torque for 39.99, regular 129.99. Came with a few impact sockets and a case, you really can't go wrong with something like that. Next time I have to remove the CS or clutch hub nut, going to break this bad boy out!
  • gscx
Posted March 21, 2011 - 01:16 PM
I really hate using a impact wrench on stuff like this. I feel like im going to break the shaft or something stupid when I really have to put pressure on it.
  • Hot  50 replies
  • 0 replies
  • 10 replies
