Hot Cam jetting
1 reply to this topic
  • seabass152
Posted March 18, 2011 - 02:13 PM
Did anyone who has installed the Hot Cams setup run into jetting problems after installing? Thinking about getting them but not if they make jetting harder than it needs to be. Thanks
Going in a 07
  • CanadianWR450
Posted March 19, 2011 - 02:21 AM
It might change a bit, but not drastically....
In my case I went hotcam's and after market exhaust and JD Jetting at the same time.....after a quick call to JD's support line, he simply recommended using the YZ settings from his jetting guide instead of the WR settings. The only change from the 2 was that the needle was one clip richer. Fine tune for your bike/conditions from there.
