front brake lever play
4 replies to this topic
  • cjxrider125
Posted March 15, 2011 - 05:36 PM
i have a problem with my front brake on my 09 yz450.
there is an inch of play when i pull the lever in, then i get a nice firm feeling to it. i just started noticing this recently and i think its gettting worse. by the time im getting good braking the lever is already hitting my other fingers that are holding onto the bar.
i just installed new brake pads and bled the line with no results and the caliper is floating freely
how can i get rid of that initial play and have a firm feeling farther out in the pull?
  • ttr250dude
Posted March 15, 2011 - 09:13 PM
Have you checked your brake fluid level? You could have a leak somewhere. Maybe you didnt tighten the drain bolt all the way?
  • Padgett
Posted March 15, 2011 - 10:15 PM
Take a zip tie and pull your lever into the grip as far as it will pull with the zip tie and let it set over night or leave it on until your ready load to go ride. This will help get any air out of the system. If it does not work, then you need to kit your master cylinder. Good luck.
  • cjxrider125
Posted March 24, 2011 - 11:02 PM
where do i find a rebuild kit?
  • Padgett
Posted March 25, 2011 - 04:08 AM
I suspect from the date of your post that the zip tie trick didn't fix it. Use the OEM kit. Its not hard to change, you just need a pair of snap ring pliers. You can get the kit from your local dealer or order it on line here at TT or some of the other popular on line stores that stock factory OEM parts.
  • 3 replies
  • Hot  28 replies
  • Hot  47 replies
