Powerbomb worth it?
6 replies to this topic
  • ttr250dude
Posted March 14, 2011 - 10:26 PM
I think I've read that it's pretty hard to beat the stock header, performance wise. So would the Powerbomb really be a night and day difference?
  • primerib108
Posted March 15, 2011 - 04:09 AM
I would say no because I have one. But it helps quite things down a bit and it is an affordable replacement if you bang up the oem.
Posted March 15, 2011 - 06:45 AM
Stock header on what?
A PowerBomb will broaden the torque curve "some" without adding any power at peak. So, you might end up with 1 1/2 hp more at 5000 RPM, a half more at 10K, and the same or a half less at 8500. You have to decide for yourself if that's worth $200. On an '03, it was a nice addition, because it took away the spike the stock power curve had in it. On an '06, it won't do much.
  • DPW
Posted March 15, 2011 - 02:31 PM
I think an '08...if that is the case I'd go with a full exhaust system if you are looking for more power. header only won't make much difference..
  • ttr250dude
Posted March 15, 2011 - 03:00 PM
I've got a 2008. All the exhaust is stock other than a Lexx endcap. I dont want to replace the muffler unless i can find one that is completely hidden behind the number plate like the stock one. Thats why i was asking about the header.
  • skull1971
Posted March 15, 2011 - 05:12 PM
I have the FMF power bomb, carbon fiber muffler,blah,blah,blah. YES the system works! and very well, BUT is it worth $1000.00 NO!! It was on my bike when I bought it. I'd save the money and put it towards a new bike, 2010-11.
Posted March 16, 2011 - 07:58 AM
What you heard was it's hard to beat the stock header on a 2010-11 model. The '08-'09 model has a header that is too large in diameter to be optimal, and should be replaced. However, as DPW pointed out, the header alone will not make much difference if using the restrictive stock muffler.
  • Hot  47 replies
  • Hot  50 replies
  • 0 replies
  • Hot  30 replies
