2010 head gasket leak
3 replies to this topic
  • cablemonkey334
Posted March 13, 2011 - 05:43 PM
just installed a new gytr head an a hi comp piston on my 2010 450 . i have some blow by on the outside of the head an i also have coolant comin out of the overflow hose . did i read the manual wrong on the torque spec . 24 then release an re torque to 14lbs.
Posted March 13, 2011 - 06:41 PM
You read that much right, but it sounds like you skipped step 3
  • Torque the head bolts to 24 ft/lb to settle and pre-compress the gasket
  • Loosen and retorque to 14 ft/lb
  • mark each bolt and tighten each one 90 degrees farther, and then another 90 degrees more, for a total of 180 degrees each
  • cablemonkey334
Posted March 13, 2011 - 06:57 PM
wow thanks for the info , i guess its off the yamaha shop for a new gasket .
Posted March 13, 2011 - 09:45 PM
RTFM :thumbsup:
If you haven't put more than a few minutes time on it, you might be able to go ahead with taking the bolts another 180 Degrees without taking the head off.
  • Hot  50 replies
  • Hot  36 replies
  • Hot  30 replies
  • Hot  38 replies
