Engine Cover Case Replacement - *** Did I Do?!?
8 replies to this topic
  • CalamariKid
Posted March 13, 2011 - 03:46 PM
Cracked my left side engine cover. Replaced it and now when I push the start button it just whirs like the starter is not engaging the engine. Any ideas? I thought I put it back together the same way - not much to it. ARGH!!!
  • strtdsmallproject
Posted March 13, 2011 - 06:22 PM
did you tap down the cover at the starter. I did the same once. I use vasoline on the part that fits over the starter and tap it down slowly and even before i even try to fit a bolt
  • CalamariKid
Posted March 13, 2011 - 06:48 PM
The cover is on fine - that is not the problem, the case was cracked from an unfortunate encounter with a rocky dry stream bed. I replased the cover and now the bike will not start. It makes a noise like something is spinning but that the starter is not engaging.
  • miweber929
Posted March 14, 2011 - 04:43 AM
Will it start with the kickstarter? You need to pull the cover back off and look around, no other way around it. Sounds like the starter gear isn't being pushed onto the starter gear. Look for binding in the shaft.
  • CalamariKid
Posted March 14, 2011 - 09:05 AM
Yep it will kick start no problem. I took it down once already after I could not get it to start. I'll give it another shot, just do not know how it could be binding.
  • WR_Dave
Posted March 14, 2011 - 09:45 AM
If you had the starter apart, you probably put the field winding housing back on backwards and now the starter is spinning the wrong way. Reverse the center housing of the starter and you may be back in business. WR Dave
  • CalamariKid
Posted March 14, 2011 - 11:13 AM
Not sure what the field winding housing is - any kind of a description would be very helpful. I like the explanation - it makes sense.
  • CalamariKid
Posted March 15, 2011 - 04:17 PM
Is it possible to mount the pick-up coil (thing attached to the stator that mounts under a guard inside the engine cover) upside down?
  • WR_Dave
Posted March 15, 2011 - 06:01 PM
It's the silver center housing of the starter. If that got put on backwards then the starter spins freely in the overrunning clutch. You didn't say if you had the starter apart, but if you did that is a good possibility. Good Luck.
