Gearing
7 replies to this topic
  • kx80boy
Posted March 12, 2011 - 11:13 AM
I have a 2006 wr 450 with stock gearing. I just put a baja designs kit on it. I was just want to know if the stock gearing would be ok for the street or do I need to change it? Thanks:banana:
  • MaxPower
Posted March 12, 2011 - 11:40 AM
[COLOR="Green"]that depends how much road riding you are going to do with it.
Dirtbikes run out of gears quickly on the road[/COLOR]
  • WR450FGreg
Posted March 12, 2011 - 01:00 PM
Definately gear it up.
(ie. larger front, smaller rear. Some call this gearing down, whatever!)
When I had mine geared for the road (mind you, with 17" motard rims) I think I had something like 16 tooth front and 42 rear or thereabouts. (Sorry, can't recall exactly what it was now.)
Take it for a run on the stock gearing and you'll soon see why you need to gear up!
Greg
  • howard113
Posted March 12, 2011 - 01:18 PM
sprocket calculator.com
for street riding,i would go up a tooth or 2 on the front sprocket.it will add lots of top speed and take away torque
  • MPNX2
Posted March 13, 2011 - 09:32 AM
http://advrider.com/...highlight=Wr450
see the link listed above... Lots of info on setting these bikes up for DS duty....
  • djv5
Posted March 13, 2011 - 01:04 PM
I believe your stock front sprocket is a 14 tooth. Go +1 tooth on the front sprocket and you will be fine.
Anything larger than +1 will require you to mod/remove the case saver.
Edited by djv5, March 13, 2011 - 03:01 PM.
  • cjyota322
Posted March 13, 2011 - 01:13 PM
I also have an 06, your stock front sproket is a 14 tooth, mine is street legal and geared up 1 in the front and its perfect for the street, does about 94mph! i'm goin back down to stock in the front and up 2 in the rear cuz i dont ride it on the street much anymore cuz it eats up tires too fast and i just started doin some hairscrambles and its a little too tall of a gear for tight trails. Go with a 15 tooth front sprocket on the front and you'll be happy with it,you probably won't even have to get a a new chain whereas you would b more likely to need a smaller chain if you went down on your rear sprocket.
  • YamaLink
Posted March 15, 2011 - 09:25 AM
Definitely stock gearing is not the way to go. I'd go 1 up in front for sure and then see what works best in back.
