Looking for rekluse clutch cable for z start perch adjuster
12 replies to this topic
  • spyr_409
Posted March 07, 2011 - 03:32 PM
got a good deal on a leftover z start and perch adjuster but i need the longer clutch cable. Is there anyone out there that might know where i can find one? ive got a 2009 yz 450 any help would be appreciated. Thanks!!!
  • spyr_409
Posted March 07, 2011 - 10:40 PM
rekluse wont have any for about 2 weeks so i was hoping someone on here might have one or might know a dealer who might have on in stock. thanks!
  • eazrider
Posted March 08, 2011 - 09:14 AM
My Z-Start used the stock cable...I've had all versions of the Rekluse, and they all used the stock cable, when a cable was used...
  • spyr_409
Posted March 08, 2011 - 05:34 PM
It does use the stock cable unless you use the perch adjuster i guess
  • eazrider
Posted March 09, 2011 - 09:51 AM
I have the perch adjuster, and it uses the stock cable. I used the perch adjuster on my '04, transferred it to my '06, and now, I'm using the same adjuster on my 2010...they all use the stock cable .....
  • spyr_409
Posted March 09, 2011 - 10:46 AM
how did you get it to fit? when everything is on the cable barely comes out of the adjuster cover is there a trick to it im just not figuring out? even rekluse said i need a different cable. Im not doubting you in any way if the stock cable will work i appreciate any help
Edited by spyr_409, March 09, 2011 - 11:44 AM.
  • eazrider
Posted March 09, 2011 - 08:12 PM
I don't recall exactly what I had to do...seems like it involved trimming a bit off of the OEM cable adjuster to get the free length of the cable to work. I believe I still have several sets of instructions which detailed what to do....
  • bg10459
Posted March 09, 2011 - 08:18 PM
Yes, I believe that's it. Though, I didn't go with the perch adjuster. I threw caution to the wind and just removed the cable and lever. Worked like a charm.... :thumbsup:
  • spyr_409
Posted March 09, 2011 - 10:04 PM
Well let me know if you come up with some instructions on how to do it and thanks for your time.
  • bg10459
Posted March 10, 2011 - 05:36 AM
Check here -> http://www.rekluse.com/ormanuals.shtml
Posted March 10, 2011 - 12:02 PM
Who would have thought to look there? :thumbsup: :smirk:
  • spyr_409
Posted March 11, 2011 - 07:52 AM
i in the instruction i have which are those say i need a different cable.
  • bg10459
Posted March 11, 2011 - 10:11 PM
Read the z-start manual, step 19....
