Valve Clearance
15 replies to this topic
  • Jekel
Posted August 02, 2003 - 10:52 AM
This question is for you mechanical gurus. The shims in are 171 and the clearance is .012. Specs say max clearance is .0118. So what number shims would be correct to get it in spec? I put it together (couldn't wait to try the 450 cam) :D :D :D and is a little noisy, but runs great. :)????? Thanks in advance :D
  • Gadsen
Posted August 02, 2003 - 03:17 PM
You'll need to find which increments the shims come in. Measure all your clearnaces, write it all down, now figure out what you'd like them to be, then go from there. You are a little outside of max, keep in mind, the valve clearances will usually decrease as the engine runs and the valves wears into the seats. Excess clearances shows up when you have some abnormal wear. Try to get them mid way. After figuring how much clearance you need to add or remove, take out the shim and measure it, record this clearance also. Then run down to Yamaha and get your shims. After you have them all in place, roll the engine over a bunch to settle it all in place and measure it again, hopefully you'll be done the first time. But if tis not, tear back in. If you get it perfect the first time, you've done good! As a Toyota tech, the Tundra/Sequoia/Landcruiser uses the same "small shim under the bucket" set up at thje Yamaha does. Shims on top of the bucket are easier, but with aggressive lift cams like the WR/YS, they'd spit these shims right out. Shims for these cost $5 each, not sure what Yamaha will charge.
  • Jekel
Posted August 02, 2003 - 05:44 PM
I would like to do that,I don't know the conversion rate between thousandths and mm. :) I know I need to know when I go to the dealer because I have doubts of their knowledge base or willingness to help. :D
  • Sylvain
Posted August 03, 2003 - 06:39 AM
Basically all the parts that compose a foreign vehicule is metric. If you have access to a digital micrometer you only have to choose the metric scale. If your dealer doesn't. May be you could rent one !
Or better, buy the tool. The cost of a good digital micrometer will be less than a visit to the "stealer", sorry I mean dealer :) :D
  • Gadsen
Posted August 03, 2003 - 06:33 PM
Its .010" is .25mm
  • Jekel
Posted August 04, 2003 - 01:26 PM
thanks. That was what I was looking for. :)
  • RichBaker
Posted August 04, 2003 - 06:55 PM
1mm = .040"
  • Gadsen
Posted August 05, 2003 - 06:10 PM
.030" = .75mm :)
2mm = .080" :D
  • jasowiii
Posted September 07, 2003 - 07:08 PM
It's exactly 25.4 mm per inch or 1 mm = 0.03937". :)
  • Junior_Vet
Posted September 08, 2003 - 08:46 PM
My head hurts from all the conversions. :)
  • R_Little
Posted September 09, 2003 - 11:11 AM
I believe the yamaha shims come in incremets of "5" which means the next size avaliable from Yamaha will be 175 (+.04mm) which might put you close to the tight side (.0104"?) if you use it.
I prefer the valves a little loose than right on the tight limit. I think you are right on the bubble.
There is a chart in the manual, I would check it and see.
Let me know if you don't have a manual and I'll check for you.
  • R_Little
Posted September 09, 2003 - 11:13 AM
I notice you say it is back together already.
If so I'd leave it and check it in a couple of months.
Get the 175 shim in hand now though.
later
  • DesertChris
Posted September 09, 2003 - 12:00 PM
www.convert-me.com
The service manual has a chart in it to convert what you clearance it to the proper shim needed.
  • racinteach
Posted April 05, 2010 - 07:47 PM
so what are the specs for the 06 wr then...I was able to do my exhaust ones..that were too tight... but can't seem to get a good read on the intakes...
  • JDLowrance
Posted April 06, 2010 - 05:30 AM
mm to inch = mm / 25.4
inch to mm = inch X 25.4
  • motodiver13
Posted April 06, 2010 - 01:59 PM
divide mm by 25.4 to get inches, multiply inches by 25.4 to get mm
