Everyone Should read this! (Cam chain troubles)
11 replies to this topic
  • Crawford43
Posted March 02, 2011 - 02:19 PM
I know everyone that owns a YZ 450 has probably heard about this problem with the cam chain and/or cam chain adjuster by now. I was looking through past threads and found this problem multiple times! I personally have had this happen three times now, the last of which caused the shim bucket on top of one of the exhaust valves to break in half! This is an obvious problem that I think Yamaha should adress. I am sick and tired of having to rebuild engines because of a silly problem. I am going to write to Yamaha to address this problem which will not only cause a servre loss of return customers, but an increased liability as this is a saftey related issue, my engine locked in thrid gear through a whoop section this last time. If anyone has any info on a solution to this problem I would like to try it because I do prefer Yamaha for their performance and reliability. If there is no solution; however, and if the manufacterer will not even admit to a problem, I will have no problem trading my blue bike in for any other color!
Edited by Crawford43, March 02, 2011 - 02:53 PM.
  • tmoney302
Posted March 02, 2011 - 02:30 PM
What's the problem exactly? I have a hard time understanding how a cam chain or tensioner could have anything to do with a valve shim breaking.
  • tmoney302
Posted March 02, 2011 - 02:36 PM
...I mean bucket. Is the chain jumping on the timing?
  • skull1971
Posted March 02, 2011 - 02:38 PM
I'm thinking going back to GREEN!!:thumbsup:
  • KJK_JR
Posted March 02, 2011 - 02:45 PM
Camchains dont last forever if that is what you are saying is the problem. They should be replaced about every 40hrs or so. They are cheap anyways.
  • Crawford43
Posted March 02, 2011 - 02:51 PM
I agree completely! What I think the problem is a faulty cam chain tensioner which lets slack in the chain allowing the cams to jump timing and "stick a valve", where the valve is actually contacting the piston and locking up the engine. Again this is the third time this has happened to my bike, and I had started checking the chain tension, changing oil frequently, and checking oil pressure with every oil change to prevent this failure. I just called Yamaha and they said there are no recalls on the producmost likely from lack of customers actually reporting the problem to Yamaha. I am going to write a letter to Yamaha and I suggest everyone who ones a YZ 450f and knows of this problem do the same. Letters can be sent to;
Yamaha Motor Corporation, USA
6555 Katella Avenue
Cypress, CA 96030
Edited by Crawford43, March 02, 2011 - 04:00 PM.
  • KJK_JR
Posted March 02, 2011 - 02:54 PM
get a manual cam chain tensioner if you feel you have such issues with the auto chain tensioner.
  • Crawford43
Posted March 02, 2011 - 03:56 PM
I just took the automatic tensioner off and it seems to funtion properly, but it was fully extended. So the chain must be wearing out and stretching, but it seems to stretch pretty quickly.
  • Crawford43
Posted March 02, 2011 - 04:19 PM
Ok. I've cooled down a little bit. I think I will just get a new chain and clean up anything that was damaged in the head. My question now is has anyone had more luck with a manual adjuster or should I just replace a chain more frequently?
Posted March 02, 2011 - 04:20 PM
If you take it off, it will automatically fully extend. That's what it's supposed to do. Any slack that develops is instantly taken up by advancing the plunger. The plunger can't be pushed back because you can't back a screw out by pushing on it.
  • dalonar
Posted March 02, 2011 - 05:50 PM
wonder if something else is going on....i ride the dog piss out of my yz450f and checked the valves for the first time since i bought the bike, hadn't moved and the chain looked fine (replaced anyway) i'm guessing somewhere in the 200 hour range.
  • Crawford43
Posted March 02, 2011 - 06:52 PM
Yeah I know because its an automatic tensioner. To colapse it you have to turn the screw inside while pushing lightly on the end of the tensioner.
  • 9 replies
  • Hot  47 replies
  • 0 reviews
  • Hot  33 replies
  • 0 replies
