AIRBOX MOD
1 reply to this topic
  • gagourd
Posted July 31, 2003 - 02:29 PM
HOW WILL THE AIR BOX MOD AFFECT THE BIKE DURING WATER CROSSINGS? DO I REMOVE JUST THE REAR PIECE OR THE ENTIRE AIRBOX LID? WILL THIS REQUIRE RE-JETTING THE CARB? :)
  • Indy_WR450
Posted July 31, 2003 - 05:53 PM
for water crossings run the upper 2 carb vent hoses to your air box. Seal your air box side cover with silicone. put glad wrap on your panel so the rubber sticks to your air box only. When dry remove the cover and peel off the glad wrap. As far as the snorkel or internal top cover you can remove it without jetting changes. Jetting changes may be needed if you get a lot of popping on decel. :)
