Hone size Help
2 replies to this topic
  • fordrocks150
Posted February 27, 2011 - 09:53 PM
Im looking to by a flex hone tool... does anyone know what size and grit i need to get for a 2009 yz450f? they also sell one for nikasil application would this be better also
thanks
  • fordrocks150
Posted February 27, 2011 - 10:06 PM
so i found that 95mm seems to be the right size for the stock bore. but still dont know what grit to use.
Posted February 28, 2011 - 07:52 AM
If you buy a Brush Research hone, the necessary oversize for the correct spring pressure on the abrasive balls is built in. Order the hone by the bore size, or 95mm, as you said.
Use 240 or 320, and avoid anything harder than aluminum oxide. Use the hone "wet":
http://www.thumperta...759#post4380759
  • Hot  47 replies
  • On January 15, 2017
  • 3 replies
  • 0 replies
