help broke case
6 replies to this topic
  • stub08
Posted February 26, 2011 - 07:37 PM
well first raace was today and 15 min in to practice chain broke and rubed a hole in the case what can i do
  • brentn
Posted February 26, 2011 - 11:04 PM
If the hole is small enough, JB weld will work.
If you can, post a pic of the hole, we can tell you if it is repairable or not, and possibly give you more info on how to go about fixing it.
  • Smokeslider
Posted February 27, 2011 - 12:57 PM
What bike?
  • stub08
Posted February 27, 2011 - 05:54 PM
its a 01 yz426 and i found a guy local that can tig weld it while on the bike:banana:
Posted February 27, 2011 - 06:23 PM
If the hole in the case pumps out oil under pressure with the engine running, you have to be careful in repairing it, because that means it's broken into the oil feed to the trans shafts, and you don't want to close that off.
  • stub08
Posted February 27, 2011 - 07:40 PM
its rite where the cluch cable is. it in rhe part where the rod that the cable hooks too you know where its round its rite ther in front of the sprocket
Posted February 27, 2011 - 09:15 PM
That's the area where the passageway is. If it's not done right, there will be trouble.
