Your thoughts and suggestions.
4 replies to this topic
  • YamaHawg001
Posted February 25, 2011 - 10:08 AM
Hey guys,
So I just disassembled the top-end of my 98' 400. The plan is to check and adjust the valves if necessary. Was actually quite surprised at how clean the valves and piston were on the old chap.
Was just gonna ask you fellas or ladies for any advice, tricks, suggestions. Also about the gaskets. The stock ones are still intact, would you suggest replacing?
Appreciate the help.
  • oakhillbiker
Posted February 25, 2011 - 10:22 AM
I wouldnt reuse the head gasket because they are metal and need to crush down I'v reused the lower gasket with no problems did you measure the piston & ring gap?
  • jcm3
Posted February 25, 2011 - 11:00 AM
I would also plan to replace the cam chain while you have it apart, if it has any age on it.
I just did the piston/rings, Hot Cams, and timing chain on my 426 recently. I can see this as the type of job that will take much longer the first time than it will the second time since you are learning as you go along that first time. :smirk:
These are very reliable bikes.
  • YamaHawg001
Posted February 25, 2011 - 11:42 AM
What do you mean gap? and how do I measure it?
  • oakhillbiker
Posted February 25, 2011 - 12:41 PM
do some research on youtube lots of good info
  • Hot  47 replies
  • 9 replies
  • Hot  50 replies
  • 0 replies
  • Hot  113 replies
