Please Help : Magura clutch on YZ450 06
No replies to this topic
  • Bennyyz450f
Posted February 18, 2011 - 07:38 PM
Hi guys i am hoping someone can help i just bought a magura clutch for my 06 YZ450 and i have got it all installed and the slave cylinder slipped right into the original clutch bracket on the engine but when i pull the lever it just does'nt engage the clutch roughly only halfway. i have put the washer spacer in and it is not much better. On the instructions it says to pull the slave cylinder out and if it is more than 4 mm gap then you have to put more spacers in but when i pull mine out it comes out about 12-14mm and if i put spacers on that the cylinder wont snug into the clutch bracket
Any Ideas anyone please or if you have had the same problem how did you fix it
Thanks.
