carb slide 06 YZ450
3 replies to this topic
  • primerib108
Posted February 18, 2011 - 09:42 AM
Are these known to be on the "loose" side of things as in it makes a slight rattle sound with the filter off and engine running?
Posted February 18, 2011 - 10:09 AM
Normal.
  • primerib108
Posted February 18, 2011 - 10:23 AM
Thanks.
I had an old Wr400 that had the carb slide crack and a couple small pieces when through the engine......wasn't sure if I was heading down the same road.
Posted February 18, 2011 - 11:21 AM
You can see the kind of wear that results in cracking and breaking the vacuum release plates as it develops if you pull the carb and take a look at the slide from the engine side.
