Yz 80 2001 model Carburetor tunning Trouble
3 replies to this topic
  • Yz802001
Posted February 17, 2011 - 10:03 PM
hi, i have recenly cleaned the whole carby on of my bike to give it a good clean. and im took the air/mixture and tunning screw out. i forget how to adjust the air/mixture screw can anybody give me a idea what it is or who knows it?
i would appreciate it alot...
i also notice when before i cleaned the carby out i had a problem when i start the bike and pull the choke out it idles fine, but when i push the choke in its like the big revs go up high and higher. and i notice i can't tune the it also, the tunning screw won't help cause its not working when i try to slow the revs down it dosent affect it...
the bike is a Yz 80/85 2001 model..
  • rcdude33
Posted February 18, 2011 - 03:49 AM
Did you set the air screw back to factory specs? It maybe idling high because its running lean.
If you dont have a manual heres a downloadable one:
all you have to do is select your bike and then begin the download:
http://www.yamahaown...om.au/index.php
  • sykal
Posted February 18, 2011 - 08:15 AM
turning the air screw in makes your bike run richer
turning the air screw out makes your bike run leaner
it sounds like your running lean.
try to adjust your air screw so that it idles cleanly
(you also might have an idle-adjustment screw)
is your jetting stock?
  • Yz802001
Posted February 19, 2011 - 07:47 PM
well the jetting is stock, and what is the air/mixture i screwed it all the way in and 1.5 half turn out.
how many turns is the air/mixture?
i know how to adjust the idle no problem there, i put a new float and main jet etc in the carby, so im going to put it all back together and see how it goes. i notice that before i cleaned the carby that the muffler that goes into the barrel of the bike was filling up with oil bout half a cup..
Yamaha YZ85 2017 by Chris.GVS
Yamaha YZ85 2017
  • 0 reviews
First Harescramble by 2000YZ250
  • Hot  36 replies
what bike? KTM,RM,YZ,KX,or CR 125 by Numsa Hul
  • 8 replies
02 YZ 125 and 04 YZ 250 Compatibility by TPA-MX
  • Hot  27 replies
How low can a dirt bike be lowered? by Numsa Hul
  • 11 replies
