07 YZ450 Brake Pedal question
2 replies to this topic
  • Blackjack44
Posted February 17, 2011 - 05:02 PM
I threw on a new Hinson Clutch cover and my brake pedal is right on the cover? I didnt have time to call Hinson today before they closed. Any suggestions? Put a spacer on? or how can you lower the damn lever. I adjusted the screw on the clevis and it did nothing.
http://s1136.photobu...nt=IMG_0061.jpg
http://s1136.photobu...nt=IMG_0062.jpg
  • Wiz636
Posted February 17, 2011 - 10:09 PM
I would just bent it out a little bit to get the clearance that you need from the clutch cover. You could use a spacer though.
Your brake lever seems a little high...it is adjustable, just look at the adjuster and use your mechanical reasoning skills.
  • Blackjack44
Posted February 19, 2011 - 05:26 PM
Mechanical reasoning skills needed a bit of help but it got figured out. It was all about lowering it.
Thanks....
