Wiring key ignition, help?
11 replies to this topic
  • RipGroove99
Posted February 17, 2011 - 01:15 AM
I have a key ignition switch that i'm tring to wire to my '03 WR450....
Wires on original push button ignition are:
RED
RED/BLACK
BLACK
BROWN
Wires on the new ignition switch are:
RED
BLACK
BLACK/WHITE
GREEN
I did try matching the RED + BLACK of the key switch to where the RED + BLACK of the push button were on the bike but promtly blew a fuse :smirk:
Am obviously rubbish at wiring so does anyone have a clue?
  • dgcars
Posted February 17, 2011 - 02:30 AM
There is probably someone who has the answer off the top of their head but you could.....test each wire with a multimeter. See what each one does in association with the other, ie continuity, nomally open, nomally closed etc. Match the 2 switches....bingo!
  • RipGroove99
Posted February 17, 2011 - 02:37 AM
Thanks but thats the problem, i'm useless with electrics, i do have a multimeter somewhere but have no idea how to use it??!! :smirk:
  • dgcars
Posted February 17, 2011 - 02:47 AM
Hmmm.....we have a problem Houston :smirk:
  • RipGroove99
Posted February 17, 2011 - 03:02 AM
lol, yeah i know!
I read somewhere that you only need to connect 2 out of the 4 wires as the other 2 are for the LED thats in the original switch.
  • RipGroove99
Posted February 17, 2011 - 05:06 AM
I have the original ignition button, the new ket switch and a multimeter in front of me but for the life of me cant figure out what i'm doing! lol I'm an engineer not an electrician!
  • dgcars
Posted February 17, 2011 - 05:27 AM
Ok crash course.....
1. Pen & paper
Set the multi-meter to resistance. (Ohms)
Now start with one wire. This will be your common. Test it with the remaining 3 wires & write down the result.
Repeat this with the other 3.
Do the same for the new switch. It will be immediately apparent when you see it in front of you.
  • RipGroove99
Posted February 17, 2011 - 05:40 AM
Cool thanks, am heading to work but will take it all with me and see whats what :-)
  • schattat
Posted February 17, 2011 - 08:26 AM
Red is the permanent 12V source from the battery (i.e. unswitched)
Black is obviously GROUND
Brown is the switched 12V power source (when the ignition switch is on, power will be on here)
Red/Black is not really important. It's just a wire than runs from the ignition unit and turns on the bright LED light on the original switch!!!
Sit alone with your multimeter and check how the new ignition switch is configured. Turn your multimeter to "continuity mode" (usually when the 2 cables from the multimeter touch each other, you'll here a beep sound from the unit meaning they're connected with each other!). Now, switch the ign.switch to off, attach the 2 mulimeter cables to any pair of the 4 wires, then switch the switch on. Should it beep, then that's all. My guess would be to first check either the pair RED and BLACK/WHITE or RED and GREEN...
Let us know how it goes :smirk:
  • RipGroove99
Posted February 17, 2011 - 09:33 AM
Thanks very much for all the info, also found an electrician at work so armed with all that i'll give it a whirl tomorrow morning before work. Will post back herw with the results.
  • ARin
Posted February 17, 2011 - 10:10 AM
Open up the original switch housing (two screws)...and look at where the wires go, two go to the LED, two go to the switch. I dont remember the colors, but that is what i did when i wired my Key.
as for the key itself, you have to check the continuity. there will be two wires that are open when the key is off, and closed when on....vice-versa for the other two.
you want the normally open (when off) ones to use as your switch wiring. the other two coming off the key switch are worthless....they are for bikes that have a different type of system. (TTR)
  • RipGroove99
Posted February 18, 2011 - 04:00 AM
Thanks heaps guys, red and brown on the bike were the ones i needed, as stated the other two were for the LED on the stock switch. Key switch works perfectly.
