2010 YZ450f Valve Clearances
17 replies to this topic
  • skullcandy
Posted February 10, 2011 - 12:51 PM
Im just waiting on some proto offset feeler guages, just wondering if you owners with 10s have checked your valves and had any movement?
Thanks guys
  • tech24
Posted February 10, 2011 - 12:57 PM
nope its a yamaha :smirk: 38 hrs: no change. Theres a few others on here with many more hours than that with no adjusments needed.
Posted February 10, 2011 - 02:38 PM
Show of hands....
How many of you remember before the 2010 came out, when there was all the abject fear that a four valve head would suddenly turn the YZF into a valve eater?
:rant:
  • Gunner354
Posted February 10, 2011 - 08:36 PM
Oh ya thought they might but once again Yamaha proved to be a solid company.
  • brentn
Posted February 10, 2011 - 09:25 PM
I think I'm at 27 hours now, checked the valves at 22 and there was no movement as far as I could tell.
I might have checked them wrong, and I learned a new technique to using feeler gauges more precisely, I'm going to check the valves again here pretty quick.
  • tech24
Posted February 11, 2011 - 07:28 AM
  • CaptainKnobby
Posted February 11, 2011 - 10:02 AM
Mine is at 30 and mine hadnt moved none. someone on here had 100 and theirs hadnt needed adjusting. I just wanted to check mine to see how hard it was to get the valve cover gasket off.
Its a lot easier and a lot easier to get to the valves than the 06 was.
  • skullcandy
Posted February 15, 2011 - 08:46 AM
Just an update I checked my valves and they are indeed "Out".
Intake
0.12mm 0.09mm
Exhaust
0.24mm 0.29mm
The spec in the book is Intake 0.10-0.15mm clearance
Exhaust 0.20-0.25mm
I should be in the clear once I do the valve set, but a whole new wack of problems as I think I stripped the valve cover bolt, and inside the spark plug boot was some dirt, once I pulled the plug it dropped into the piston. Ahh the joys of having a dirty hobby.
  • brentn
Posted April 18, 2011 - 06:45 PM
Update for my bike, 29.5 hours with lots of WOT, hill climbs, slow and hot. Bike has been ridden fairly hard, just trying to indicate that it has not been babied at lower RPM's or anything.
Intake
I don't have a full set of feeler gauges, so I could only measure .13mm to .15mm and .10mm. The clearance is at .11-.12mm for both. .15, .14 and .13 would not fit, and .10 would, so like i said somewhere inbetween.
Exhaust
Both are exactly
.23mm
I had a small set with only a few sizes, but I did alot of combining of gauges to get specific clearances. To check for .13 I would combine a .06 and a .07. If anyone thinks this is a bad idea let me know and I'll try and find a full set with individual clearances.
Pretty happy, looks like things are good and my maint seems to be up to par.
  • Gunner354
Posted April 18, 2011 - 06:58 PM
:thumbsup:
  • todds924
Posted April 18, 2011 - 08:12 PM
Intake
Exhaust
Both are exactly
.23mm
Please spend the 8 dollars on a "full" good set!!! You'll get a better feel than doubling up on um.
  • HighRevz
Posted April 19, 2011 - 05:51 AM
Sorry for the bad spelling but doubling up on them is a bad method to use when you're dealing with such similar increments. A slightly "not straight" blade put against another blade will represent something larger than you think. YOU CANNOT SEE IT either :thumbsup:. In the net result.....Just use one blade and get some quality, accurate, tappet blades.
  • brentn
Posted April 19, 2011 - 06:10 AM
I would have easily spent 8$ here on a decent set, if you could find one!
Only place to get a decent guage set is online...
I didn't think that it was such a bad idea...
  • jonha
Posted April 19, 2011 - 08:18 AM
Where and who makes a really good set for checking valves? I have a few sets and none of them are what I think they should be.
Posted April 19, 2011 - 11:42 AM
I use the normal, standard width, straight blade 4" feeler gauges. Not a problem.
  • todds924
Posted April 19, 2011 - 09:15 PM
Snap-On, Matco....Or General. Around 8- 12 bucks depending.
  • powers450f
Posted April 19, 2011 - 09:21 PM
I see some people are reading them out rather than in. they get tighter not looser this isn't a lifter motor Its dohc....
  • motoman808
Posted April 20, 2011 - 05:57 AM
napa has a good set
