counter shaft seal
6 replies to this topic
  • Gaffo
Posted February 08, 2011 - 11:12 AM
hi guys i know there has been a lot of threads about this but i still cant seem to find the answer to my problem, i have changed my counter shaft seal 3 times now and still cant stop it leaking there is no play in the bearing and shaft seems fine (not bent) the only thing is the seals are not yamaha parts,its starting to piss me off even though these are great bikes im seriously thinking about selling it, really dont want to tear down the engine,any help would be appreicated:banghead::thumbsup::banghead::lol:
  • 123BigcoopDawg576
Posted February 08, 2011 - 06:32 PM
Really? You do know this isnt the KTM forum right :( :lol: :ride:
IMHO I'd start with ordering the correct OEM replacement...then report back to use :thumbsup:
  • tribalbc
Posted February 08, 2011 - 07:17 PM
And replace the oring and collar as well....
  • Birdy426
Posted February 08, 2011 - 08:07 PM
+1 on the o-ring and collar!
  • GuyGraham
Posted February 09, 2011 - 04:59 AM
OEM seal is £19 in the UK
Std dble lipped oil seal is only a coupl of quid from a bearing factor
However, the OEM seal is not a std seal - it has a larger ribbed lip on the inner side
This may be the cause of your issues
If your seal is leaking, as said above, always change the collar as well.
Posted February 09, 2011 - 09:23 AM
A mistake commonly made with the YZF/WRF is to install the seal too deep in the bore. When this is done, the lips of the seal may over hang the "castle" notches on the inboard end of the collar, creating a built-in leak. The seal needs to be inserted square with the bore, and positioned so that it stands proud of the end of the bore by about 1 mm or less, but no more than flush with the case.
Definitely inspect the collar. Any distinct groove worn in it will keep it from sealing.
  • Gaffo
Posted February 10, 2011 - 04:37 AM
Thanks for all the help I'll get all the new parts and let ye know how I get on
