WR450 Kick Start Idle Gear Explodes... Why?
11 replies to this topic
  • Too Slow
Posted February 04, 2011 - 11:17 PM
Hey Everyone,
Was adjusting my mixture screw on my 2003 WR450 and the battery was low so I was kicking it a bunch. Started it up and went to load it in the truck and heard a bang from inside the motor. Stopped and found that the kick start was no longer engaging. :lol:
Pulled it apart and found that the kick start idle gear blew into pieces, chipped a tooth on the primary clutch basket and broke two bolts where the stopper goes. :thumbsup:
Anyone have any ideas as to how this happened?
PS if anyone has a stock clutch basket for sale, I have an ad in the wanted section.
  • schattat
Posted February 05, 2011 - 01:47 AM
It looks as though the kickstart stopper (small piece of steel fixed into place by 2 screws) may have failed and snapped off and somehow got jammed into the gear thus destryoing it...
  • MANIAC998
Posted February 06, 2011 - 04:26 AM
First picture, lowest piece on the left. What the hell is that? I can't figure out where that came from. Also, you probably weren't done cleaning up the engine yet, but in that last picture, there's more gear material hiding in there. Maniac
  • dgcars
Posted February 06, 2011 - 04:43 AM
Looks like the remains of the stopper & 2 securing screws???
  • bg10459
Posted February 06, 2011 - 06:35 AM
+1.
A hard kickback can break the stopper... and the ratchet... and the gears...:thumbsup:
  • schattat
Posted February 06, 2011 - 06:40 AM
A hard kickback can break the stopper... and the ratchet... and the gears...:lol:
Ask me how I know :ride:
I was able to get my WR for cheap $$$ after the previous owner had this problem:
Whilst trying to kickstart the thing decided to kick back and therefore the stopper snapped and caused the kickstarter-shaft to jump out if its seat and rip a chuck out of the casing :(
I was still able to fix it, though :thumbsup: Has held up over 6000kms now :lame:
It looks a bit cleaner now after I removed the metal putty that was over the welded part...
  • BajaFool
Posted February 06, 2011 - 10:01 AM
Did the bike have the Starter Idler Gear upgrade to the 2004 model year configuration?
  • danfromnb
Posted February 07, 2011 - 05:22 PM
I'd say your kick start stopper broke first, taking the rest with it. Mine did last summer but I was REALLY lucky and the piece that broke off the stopper stayed between the gear and case making a light ratcheting noise (almost like the kickstart was being held down). I stalled on a hill and kicked it hard at a weird angle and it kicked back. The worst part of my whole experience was that the stopper was backordered and I had to wait a couple weeks.
Here's what mine looked like:
BTW: BIG thumbs up for your cardboard mock up to keep your fasteners straight. I was showing an apprentice at work how and why to do that today.
  • danfromnb
Posted February 07, 2011 - 05:50 PM
I just thought of something else to add:
Once I did get my bike back together I did a couple laps around the yard and rechecked for leaks, fluid levels etc. Everything was great so I tossed on my gear to go for a short ride. Halfway down my driveway smoke started to billow out of the bike and I could smell oil. Hit the kill switch and looked around, saw oil dripping from the rad... ***!? Turns out there is a crappy plastic plug held in by a set bolt where the decompressor lever came out of the head on older models and this plug blew out. I searched for the problem here on TT and found the commonly accepted way (best IMO) to fix this was an 18mm steel freeze plug. I just tapped it in with a deep socket that fit it well and after rechecking it a couple times, forgot it ever happened. I can't remember for sure but I think it was an 03-04 problem only, later years had a recast head with no hole.
I have no way of knowing for sure but I suspect the same backfire that killed the stopper generated enough of a pressure in the crankcase (and oil galleries etc) to loosen this plug enough for it to fall out. If it was me I'd replace it now. Go to a local engine shop and ask if they have one, they'll probably have to dig as it's a fairly uncommon size.
  • Slick_Nick
Posted February 07, 2011 - 06:18 PM
That's crazy!
  • schattat
Posted February 08, 2011 - 04:06 AM
Mate, you were lucky to get away with that! My bike needed a tonne more work done, see here :thumbsup:
Wooded support:
The hole where the kickstarter shaft sits was no longer round and stright, so I rewelded the spot with a alloy bushing I made to fit the shaft and milled it down to make it flat and clean:
Not the cleanest solution, but why bother when you can't see it anyways, right? :lol:
  • miweber929
Posted February 08, 2011 - 05:21 AM
Looks good and solid. Better than buying a couple cases for sure!!
