Yamaha WR450F mod
3 replies to this topic
  • ASEMA
Posted February 04, 2011 - 10:06 AM
I have a Yamaha WR450F 07 and i just bought the GYTR powercore4 by FMF and head pipe PowerBomb by FMF too, I was looking to increase HP in the whole range of RPM but specially at low RPM since I ride most of my time on tight trails. Someone told me that i will loose torque on low RPM,
Someone knows if i did the right thing? please give me some advice?
Posted February 04, 2011 - 10:08 AM
They were, shall we say, mistaken.
  • ASEMA
Posted February 04, 2011 - 10:15 AM
Thank you so I will increase HP trhough all the power band right?
Posted February 04, 2011 - 02:19 PM
Not necessarily, but you won't lose low end pull, either.
If you are changing from a stock WR system, then you should get a significant improvement from the pipe. On a YZ450, the PowerBomb has the effect of making the power curve higher at the low end, slightly higher or about the same at peak, and about the same or a bit better at the top end. It should do fine on the WR, but don't be surprised if you have to work on the jetting quite a bit.
