500cc Big Bore Stroker Kit
5 replies to this topic
  • Nickm27
Posted February 03, 2011 - 07:56 PM
Ive been looking into this kit... here is what it comes with
YZ450F CYLINDER WORKS BIGBORE +3mm (98mm) CYLINDER KIT 2006-2009 21003-K01 Cylinder Works cylinder: Size: +3mm (98mm bore)
Vertex 12.5:1 Piston +3mm (98mm), complete ring set, piston pin, retaining rings, gasket kit included
YZ450F HOTRODS STROKER CRANKSHAFT +3 (06-09) #4173
YZ450F main bearing and seal kit (06-09) #K022
Cometic Complete Gasket kit for the Yamaha YZ450F 2006-2009
This complete gasket sets include all gaskets necessary to rebuild the engine and transmission
Anyone have any experience with these? I will be running stage 2 hotcams as well....
thanks for any info in advance
  • dvn
Posted February 04, 2011 - 04:09 AM
Just make sure you send it out to be balanced.
  • DC_Excitement
Posted February 04, 2011 - 04:55 AM
i put that same combo in an 06. went smooth and the thing now is scary fast, your gonna have to play with the jetting after though
  • Nickm27
Posted February 04, 2011 - 04:07 PM
Sweet! thanks for the replies. Im seriously considering buying it, I think it would go well with the stage 2 cams with out having to mess with the valve springs... Im not really wanting to go that far yet..but i will if i need to. Id like to see how this feels once i install it all. then i can go further into the head if i feel like i need more...
Im trying to get some dyno charts out of them but havent recieved any emails back so far.
dvn: Where would be a good place to have it all balanced? I was hoping the yamaha dealer near me was able to?
davecarrr: tell me more about your 06 450.. what mods did you combine it with besides tuning the carb? pipe? silencer? head work? what comp ratio was the piston you ran? this comes with a 12.5:1. let me know man thanks
  • 450motard
Posted February 04, 2011 - 06:10 PM
I've never seen a dealership with this kind of equipment - I would imagine they would simply send the work to someone else and then charge you a mark-up. Save yourself the hassle and find a decent engine builder and go straight to the source.
  • Nickm27
Posted February 05, 2011 - 10:37 AM
ok, I will have to check around... i dont know anyone around my area that can balance a dirtbike motor..
Davecarrr: did you have yours balanced and if so where did you send yours to?
  • Hot  113 replies
  • On January 15, 2017
  • 0 replies
  • Hot  47 replies
