Gave my 15 year old son my old 02,Crf450r, had it re-sprung and re-valve for his weight for Dez riding. he rides it well except for hilly, technical rocky single track stuff.
I know a heavier flywheel weight is needed, but I don't know what weight and brand to get.
Thanks in advance for any advice !!
Nick
02, CRF450R Flywheel weight ???
Started by
Ho450
, Feb 02 2011 02:11 PM
8 replies to this topic
Posted 02 February 2011 - 02:57 PM
Trail Tech and Steahly are a couple of the well known manufacturers. If doing both WFO desert and single track you proably dont want to go too big, unless you want to tame the beast and mellow it out for your son. I would guess around a 5 or 7oz.
Posted 03 February 2011 - 12:16 PM
I just put a 13 oz in mine for trail riding ,i got it from SFB Racing , they make them in 13 ,11 ,9 , 7 oz , the weight of the stock flywheel is 22 oz with a 7 oz it would be 29 oz , mine is now 35 oz with the 13 oz weight , which is highly recommended for real tight stuff , just make sure when ordering any add-on weight that you tell them its for a 02 , it bolts up different from all other years , and only a weight for a 02 will bolt on , or you can go the other route and get a complete flywheel , in which ALL CRF450R flywheels will fit (and i believe 250R flywheels will also fit it) , but if you go with a 35 oz flywheel or a 13 oz weight you will have to grind a little casting on the inside of the ignition cover (just takes a minute) , and bend the tab on the timing chain retainer tab (it keeps your timing chain from dropping in your case when cam is removed , and will rub on the back side of the weight until its bent) , but your instructions should tell you about this issue
As far as price goes , i called SFB and got mine for cost ($65 shipped) retail is $120
Posted 03 February 2011 - 02:01 PM
I`v have 13 oz. on my 02 , and like i for woods. Bike still has all the power , and more power than i need. For a 15 years old you should put a cement block on it so he can`t run circles around you !!!!
Posted 04 February 2011 - 12:33 PM
The 02-03 flywheel is heavier than the 04 and up flywheels. I forget by how much. But a heavier flywheel wont affect overall power out put, just how that output feels and the way the rear tire hooks to the ground.
If he's running desert a heavy flywheel will make the bike much more rideable. Becareful about which flywheel you end up getting. Some have better magnets in them and can actually over drive the ignition and cause it to cut out. Trailtech had a bunch that miss boxed I think. If you do a search on flywheels in this forum you'll have a bunch of reading to do.
Posted 05 February 2011 - 09:25 AM
i have 2 stealhy weights out of our 07 and 08 that we traded off. they were both supposed to be +9 oz. but i weighed them out of curiosity and one of them was +11 oz. the company couldnt explain why the difference.
Posted 06 February 2011 - 12:19 AM
one could have been an 02-03 +9 and the other could be an 04 through 08 +9
Posted 06 February 2011 - 07:28 PM
oakhillbiker said:
or you can put a steel clutch basket in and do the same thing
Or both. I have the +17oz steahly, and a steel clutch basket. This thing is a hill climbin, single track MONSTER, I just wish I could ride it to it's fullest potential.
