Are there any aftermarket exhaust systems for the 2008 450? Will the 2009 system fit the 2008. I'm looking for a lighter exhaust for my 2008 TE 450
2008 te 450 exhaust
Started by cs99, Jan 31 2011 01:18 PM
7 replies to this topic
Posted 31 January 2011 - 01:18 PM
Posted 04 February 2011 - 05:59 AM
Arrow makes exhaust systems exclusively For husky Bikes. I've got one on my 08 te450 and like it. Quite a bit lighter, a bit louder And with the 02 plug and resistor mod made the bike run much smoother. You should be able to get it at any dealer like halls, motoexotica Ect. I don't think the 09 will work with the 08.
Posted 04 February 2011 - 07:12 AM
Jason is right. I researched this ALOT for a buddy last year and I doubt it has changed. The 2008's had a unique system. 2009 and 2010 are the same and don't bolt up to the 2008. There is no aftermarket for the 2008 like there is for the 2009 and 2010. Your only option is the Arrow Powerup slip on for the 2008 exclusively. But its a good pipe, flows better, lighter, but is louder too. You could purchase or make/ modify the insert (spark arrestor) to be quiter if need be.
Posted 04 February 2011 - 07:27 AM
Thanks for the information, I'll check with Hall's and a couple other places,
Posted 30 January 2012 - 02:43 AM
Somebody has told me the TC 2008 std exhaust that is Titanium will fit the TE 450 2008. has anybody tried this & does anybody know if this is true? also is the TC exhaust a performance (non cat) Arrow system?
Posted 30 January 2012 - 05:16 AM
the TC should be a MX pipe - so no cat in it,
as to wether you need the TC headers too,
I'm not sure,
Charlie
I'm not sure,
Charlie
Posted 31 January 2012 - 04:26 AM
I'm not sure,
Charlie
I'm not sure,
Charlie
Thanks for the feedback charlie,
I might be able to purchase the whole system including headers off a TC 08 and was wondering if it would run lean if i just fitted it?
The TE has the cat in the rear can and the TC doesn't, also the TC exhaust is made from titanium so you'd get a weight saving compared with TE system.
I read this on husky cafe and it appears he had a remapped?
http://www.cafehusky...fication.16491/
Can i fit and then get a husqvarna dealer adjust the fueling via i-beat? will i-beat allow you to adjust fueling on 2008 ECU?
Cheers
