2007 YZ450F Stator Cover Removal
4 replies to this topic
  • Blackjack44
Posted January 25, 2011 - 09:50 AM
Has anyone removed the stator cover on a YZ450? Looked over the schematics and cant tell if it will be real easy or a chance to mess something up.
Posted January 25, 2011 - 10:01 AM
Pull the shifter off and remove the cover. Nothing to it. If you don't want to disconnect the wiring from the min harness, then hang the cover on the bike with a wire or whatever so as not to stress the stator harness.
There is a dowel pin and an O-ring at the top that you might loose, and you may want to either drain the oil or lay the bike over a little.
Manual:
http://www.yamaha-mo...uals/index.aspx
  • Blackjack44
Posted January 25, 2011 - 07:12 PM
Thanks I appreciate your help...
  • RJacks
Posted January 26, 2011 - 12:02 PM
might lose,[/url]
?? Loose?
Do you mean lose?
  • tech24
Posted January 26, 2011 - 12:07 PM
if it seems funny removing it, its because the magnetic flywheel trying to hold things together so don't be alarmed and just pull er off
  • 10 replies
  • On January 15, 2017
  • Hot  38 replies
  • Hot  36 replies
