extra bar clamps,longer bolts?
3 replies to this topic
  • bart9505
Posted April 11, 2001 - 03:16 PM
I've seen posts about raising the bars by turning the upper bar clamps over, getting a second set and some longer bolts. I like the idea, but where do I get longer bolts and just the upper clamp set?
'01 426 with yz stop and baffle removed. No other mods yet.
  • bart9505
Posted April 16, 2001 - 07:57 AM
Anyone???
  • Rich_in_Orlando
Posted April 16, 2001 - 08:43 AM
I got mine at a local hardware store that has an extensive selection of metric fasteners. If my recollection is correct, I bought 50 mm, flanged, shouldered bolts. If you get them too long, you'll have to cut them down to size. The only thing I don't like about them is that they take a 13 mm wrench. I salvaged the upper clamps from a triple clamp I took off an XR250. A cycle salvage yard should have something like that.
[This message has been edited by Rich in Orlando (edited 04-16-2001).]
  • Derek_Burns
Posted April 16, 2001 - 02:09 PM
I was thinking about this today.... as I need to lower my front end to match the amount I lowered the rear (just to reach the floor)..... did a motocross meet today and the bike handled badly through loose dirt... I was having a pig of a time. I put it down to the difference it's made to the rake angle.
A guy at the meet had pro taper bars fitted to the standard yoke, there was a spacer which had a cemi circle machined into it so as it mated perfectly with the standard yoke clamp, and the larger dia for the pro tapers was machined into the spacer further up. I was wonering if spacers like this were available for standard bar dia.... would allow me to drop the forks just that bit more to suit the rear...... Anybody??
