Mod questions 07 yz450f
11 replies to this topic
  • Nickm27
Posted January 22, 2011 - 10:22 PM
I have an 07 YZ450F My mods are as far as the engine goes: SS mega bomb, power core 4, zip ty mod, boyesen quickstart 3 with adjustable leak jet, adjustable air fuel mix screw, my carb is 160 main, stock pilot, down 1 notch on stock needle lifting it up one setting.
Im looking for more power, more mods
I weigh 210-220lbs. Im needing some more power any suggestions would be great!
Go Yamaha!
  • ttr250dude
Posted January 22, 2011 - 11:44 PM
Cams, porting, high comp piston, etc
If u want more low end, grab an '06 cdi.
  • Nickm27
Posted January 23, 2011 - 12:08 AM
I have been thinking about cams and piston...
What does the 06 cdi do???
  • ttr250dude
Posted January 23, 2011 - 02:31 AM
The '06 timing curve provides more low end than other years.
  • Nickm27
Posted January 23, 2011 - 01:22 PM
Ok thanks... Any suggestions on cams/pistons to run.
  • Slinkyman16
Posted January 23, 2011 - 02:11 PM
I'm running the je 13.5.1 in my 07 with the pro circuit cams.. But u will have to replace the springs to run this cam.
  • FiremanKay
Posted January 23, 2011 - 02:34 PM
Can you give us a quick rundown on the power characteristics?
  • Slinkyman16
Posted January 26, 2011 - 12:58 PM
Well it's hard to give u a comparison. My motor is built. I have je 13.5.1, pc cams, pc springs/retainers and dlc coated buckets, and the head Is ported by pro circuit. The motor has a power characteristic of a spaceship. Their is no extreme power hit but more of a extemly smooth powerful pull that never signs off till it hits the stopper.. If u need power just twist it harder.. Need to get over a double with no run just twist.. Get the idea?
Pc builds the engines to be smooth but powerful to not ware u out.
  • RJacks
Posted January 26, 2011 - 01:10 PM
From my understanding, not without the cams too. The cams from an '06 will be a better mod than a CDi from an '06. And the '07 wasn't too far off, most probably couldn't tell.
Posted January 26, 2011 - 01:44 PM
That's incorrect. The CDI has a greater overall effect by itself than the cams do by themselves. Also, several people have taken the approach of swapping in only the '06 exhaust cam, leaving the '07 or '08 intake in place to retain more of the top end power.
  • RJacks
Posted January 26, 2011 - 05:53 PM
Annd swapping in just one cam will not be as effective. In my tests, swapping both cams is far greater in the "seat of the pants" feel than just a CDI alone. I have tested it, and have felt the difference in an either/or set up. Not going into an '08 or '09, that would probably yield better results. With the '07 I've noticed better throttle response with just a CDI swap. The '07 wasn't all that far from the '06 in overall power and feel. I completely disagree in the cam vs. CDI debate. Cams IMHO have a better feel in gain than a CDI does.
  • Nickm27
Posted January 28, 2011 - 07:26 PM
Well i ordered the stage 2 hotcams. ex and in. with a new wiseco timing chain. new adjustable timing gears... anything else i should do while im in there????
Also after installing my adjustable air-fuel screw, boyesen quickstart 3, mega bomb header, powercore 4 muffler. I started the bike and within seconds my header was bright orange!!!! I know this means lean but how do i correct it? Im running a 160 main and all other jets are stock to my knowledge...
any quick help would be much appreciated as im going riding tomorrow
  • 5 replies
  • 0 replies
  • 0 reviews
