2001 Rear brake mount.......
4 replies to this topic
  • YZR426
Posted March 27, 2001 - 10:13 PM
I just pulled the rear wheel off my bike and as you know, you take the rear brake unit off the swingarm at the same time. Well once I had the unit off I had a quick inspection of the swingarm locator (on caliper)and it has worn where it locates on the swing arm.
About .125mm not all the way along but around 1/2 the way. Has anybody noticed this as well?
The rear wheel wasn't loose and the brake assembly was correctly located.
  • Scott_F
Posted March 28, 2001 - 11:04 AM
The "tongue and groove" does not need to be a tight fit. When the axle is tightened, the carrier will not move.
An 1/8 of a mm is only .005".
  • YZR426
Posted March 28, 2001 - 03:17 PM
Scott F,
I realise the measurement(0.12mm)but I got carried away :).
The caliper must be moving even though the rear axle is done up tight!
I just needed to know if anyone else has noticed abnormal wear? next time you have the back wheel off check your tongue and groove to see if it's worn.
I do drag the back brake a little more than the average guy due to my days in road racing.
Thanx heaps
YZR
  • yzernie
Posted March 29, 2001 - 06:11 PM
YZR426,
I had mine off yesterday and did not notice anything abnormal. It is common for a little bit of wear to occur there. Keep an eye on it to see if it continues to get worse.
yzernie
  • Scott_F
Posted March 30, 2001 - 06:00 AM
I have had my swingarms polished, and the brake boss was noticeably worn down by the polishing. It had no adverse effect on brake performance.
  • Hot  113 replies
  • Hot  36 replies
