We're re-jetting!
We will be performing site maintenance today May 25th) today. You make experience a temporary slowdown during this time. Don't worry, we'll be back at full speed in no time.
cleaning weathered plastic
6 replies to this topic
  • mjet
Posted January 20, 2011 - 05:09 PM
Hey,guys can anyone give me any tips on cleaning weathered plastic, is it worth it. I would like to keep the sc 500 as original as possible.Im not sure if they paint it and where can i get the paint code to match color.
  • DuffyDidIt
Posted January 21, 2011 - 03:38 AM
Try using armor-all cleaning wipes, they pull the dirt out really well if you its just dirt. If its really bad you will need new plastic.
  • scalejockey
Posted January 21, 2011 - 06:03 AM
Iv'e tried i light sanding then an automotive clear coat,it worked fairly well.
  • ulmanb
Posted January 21, 2011 - 06:29 AM
I just did the following on a 1989 yamaha quad plastic. The quad looked like it spent considerable time in the sun over the years. The plastic looked sun-rotted, was faded and the surface was kind of a chalky feel.
Started with a fine grade steel wool (00 or 000), got rid of the chalkyness and made it pretty smooth. Then I used a coarse rubbing compound followed by regular wax. Came out pretty nice, restored a lot of the luster.
  • Motosprtman
Posted January 21, 2011 - 07:38 AM
:smirk: - same thing I do!
  • drturnip
Posted January 21, 2011 - 09:39 AM
Ditto on sanding + semi-gloss clear-coat.
  • timbuckets
Posted January 21, 2011 - 03:19 PM
Agreed, in fact if you want to get really into it:
  • Remove any stress cracks (those white lines) with a little bit of heating - like the low heat part of a propane torch
  • Start doing cycles of higher and higher grit paper until your at 2000 grit.
  • Then do 2000 grit with a little bit of water
  • If you are going to paint then get your favorite plastic filler product, apply and start again with the sand paper. Repeat as needed
  • Once your 100% happy you can paint/clear coat it
Regardless of what people say, you can make old plastic look new again. Its just a lot of elbow grease.
