Shifter Rubbing Crank Case Cover
8 replies to this topic
  • climaxx dirtbikes
Posted January 20, 2011 - 02:45 PM
(07 450 like new) My shifter is slightly rubbing my crank case cover ever more and I am thinking of taking the shifter off and bending it out a little. Anyone done this with or without problems? The clearance is too tight but I nudge it over with my boot when I am shifting fast.
  • Colorado Fatboy
Posted January 20, 2011 - 03:41 PM
If it was mine I'd go ahead and bend it out. Shouldn't hurt anything.
  • davidl9999
Posted January 20, 2011 - 03:43 PM
Go for it. Bend it in a vise, not on the bike.
  • tribalbc
Posted January 20, 2011 - 05:58 PM
Well it's aluminum and it won't bend that easy. You can try some heat, but if you really want to change how close it is, I would recomend getting an aftermarket steel one, and bending that.
  • Baja trail Rider
Posted January 20, 2011 - 06:10 PM
We have 07 wr450s,problem when the shifter gets bent on the trail.You cant bend it back on trail side.At your house no problem in Vise.Also know a few guys that broke the shift shaft off.So we replaced the shifter with a stock xr400,yes it bends.But we can bend it back easy,also no broken shift shafts.The IMS replacement works real good to brake off the shift shaft
  • climaxx dirtbikes
Posted January 21, 2011 - 04:06 AM
Thanks! I guess I will try the vise then aftermarket shifter if necessary.
  • strtdsmallproject
Posted January 21, 2011 - 07:42 AM
had to bend mine out a couple of times, no problems yet. As much as i crash i am always bending brake and shifter lever.
  • Shred Jesse
Posted January 21, 2011 - 01:25 PM
+1 !
It also allows for trailside "repairs" in the event of a crash. Just brand and bend!
  • climaxx dirtbikes
Posted January 29, 2011 - 06:24 AM
Alright I bent mine out with no trouble. Thanks
