End cap wont come off
10 replies to this topic
  • ttr250dude
Posted January 18, 2011 - 11:00 PM
I'm trying to replace my stock end cap for a Lexx end cap. I drilled out all the rivets, pushed the left over part of the rivet in, cut the seal between the end cap and muffler, and i even drilled the rivet holes 1/16 larger than they should be. The end cap still wont come out!! What do i do? :smirk:
  • bmxdad2001
Posted January 19, 2011 - 01:24 PM
I just did this last week. If you have a rubber mallet great, if not, I used the rubber handle of my hammer. Lay the silencer on its side and give it quite a few good blows. Turn it over and repeat. It took about 5 minutes of beating on it from different angels before it moved. Once the seal loosens up, you can grab the end cap with your hand and wiggle it and force it side to side as you pull on it. It will eventually come out. Just a little patience and beating on it is all it takes. Good luck.
  • ttr250dude
Posted January 19, 2011 - 01:32 PM
Awesome thanks. I'll try it and get back to u later tonight.
  • ttr250dude
Posted January 19, 2011 - 03:42 PM
Done. Like u said i just had to work it out with a hammer and pryed it out with a screwdriver. Crazy question, how loud would it be without the packing? Or if you were to take some of it out?
  • bmxdad2001
Posted January 19, 2011 - 06:54 PM
I left all my packing in. Its just loud enough with the new end cap on, but not too loud.
  • FiremanKay
Posted January 20, 2011 - 06:53 AM
Sound is the biggest enemy of our sport, its best to keep your bike as quiet as possible :smirk:
  • jasonlion54
Posted January 20, 2011 - 10:01 PM
Without packing it will be louder and make less horsepower.
  • ttr250dude
Posted January 20, 2011 - 11:14 PM
It was just a thought. I don't plan on removing the packing. How would it make less horsepower?
Posted January 21, 2011 - 07:32 AM
The packing, when it is solidly in place, makes the perforated core behave more like a tube with respect to the transportation of exhaust gases out of the system. Without packing, the gases will pass through the perforations to a much higher degree and impede the outward flow.
  • ttr250dude
Posted January 21, 2011 - 09:15 AM
Gray, you are completely incorrect. What an awful answer. Haha just kidding. Thanks 4 explaining it. Where did you acquire this plethora of dirt bike knowledge?
  • jrny426
Posted January 21, 2011 - 11:26 AM
also the muffler gets hot as hell melts whatever comes in contact
  • Hot  33 replies
  • Hot  47 replies
  • 5 replies
