Following new bike manuals
7 replies to this topic
  • 2biker
Posted January 17, 2011 - 06:14 AM
Have just got a 2009 from a guy had only two tank fulls ran through it i did the first oil change looked good no issues and the bike runs fine. the owner manual reading it has you check valve clearance every 5 race or as required i just ride trails no racing I keep the bike lubed and inspected but how much internal work is really required the manual has the internals inspected alot. i am 50 years old and don't ride as hard as I did in the 70s. Great website
Edited by 2biker, January 17, 2011 - 06:15 AM.
yz450
  • 2biker
Posted January 17, 2011 - 06:15 AM
this bike is a yz 450 sorry
  • Smokeslider
Posted January 17, 2011 - 02:50 PM
I check mine every 15-20 hours unless I reshim, in which case I'll check in a tighter interval to make sure things are ok.
  • 2biker
Posted January 17, 2011 - 04:32 PM
thanks chad iam new to the big fours. i just thought they were not so finicky that they have to inspected so closely.i will be studing the manual to do the inspection. i have installed bark busters,rock quard,rerouted hoses,thought about smaller front sprocket also.hearing different thoughts on 13t to 12t.
  • Smokeslider
Posted January 17, 2011 - 04:52 PM
I kept my front sprocket stock since I ride a lot of varied terrain, it just seemed to make sense to keep it stock. If you rode a 2004 CRF450 I would tell you to check you valves every 13 minutes but the Yamaha bikes do pretty well in regards to valve wear. I recommend getting the motion pro feeler gauges for checking the clearances, they make the job a lot easier.
  • BlackT5
Posted January 18, 2011 - 05:32 AM
I check mine every 10 hours. They have never budged. Its east enough to do. Its a perfect time to pull the body work for a good cleaning.
  • tech24
Posted January 18, 2011 - 07:17 AM
I ride a mix of stuff heres my intervals
oil and filter: 5-8hrs
air filter: usually every ride
check valves: every 20hrs
timing chain: every 50hrs
top end: 100 (probably wont need but I'll do it anyway)
bottom end: Inspect rod bearing during top end job and replace as necessary
(hopefully well into the hundres of hours)
  • 2biker
Posted January 18, 2011 - 08:27 AM
Getting hour meter on my way home today and if i read write wrap the wire around sparkplug cap then i can keep up with the pm ,s Thanks
  • 10 replies
  • On Yesterday, 06:20 PM
  • 0 replies
