426 timing marks
5 replies to this topic
  • 510thumpstar
Posted January 14, 2011 - 12:51 PM
Hi guys i am puttin together my friends 425 and i really dont know what im doing lol . ive done top ends on two strokes a bunch of times but never on a four stroke except a bunch of big bore kits on 50's . this bike broke a valve and we removed the top end the crank and con rod are good but the whole top end is wiped out . since the bike is so old we bought a complete used top end from ebay .. i know were rolling the dice .. basically i need to know how to set up cam chain timing . and i think i can do the rest myself . If anyone could post some pics or just explain how to set up the chain timing i would really appreciate it . the poor guy bought the bike and it ran perfect then rode it for 5 minutes and the valve broke he is a dad with three kids and is outta money do were trying to do it as inexpensive as possible . thanks for any and all replys . Ricky
  • VFRCaptBob
Posted January 14, 2011 - 01:04 PM
Valve Adj. http://motoman393.th...ech/valves.html
In lash is .10 - .15 mm Ex. lash is .20 - .25 mm at TDC
There is also a down loadable Pdf. shop manual available for his bike. Check the sticky section at the top of this category for all the information you need.
  • 510thumpstar
Posted January 14, 2011 - 01:21 PM
oh boy i keep reading all these posts on how to do it and im getting scared lol .. i guess once its done ill be like duh that wasnt that bad .. its just a little intimidating i guess . Ricky
  • jpgentry
Posted January 14, 2011 - 09:13 PM
http://www.southbayr...ead.php?t=21788
A wr but this may help I hope
  • VFRCaptBob
Posted January 16, 2011 - 01:52 PM
The actual process is very easy however you have to do everything correctly to avoid a costly or time consuming failure. I've fished the cam cap register half ring from several nooks and crannies of the motor and hunted for a dropped shim for hours only to find it the next day under my truck in the driveway. Key is don't rush anything and follow all the steps.
  • Doete36
Posted April 26, 2011 - 08:23 AM
Good post, better than the manual!! thanks for the help
  • Hot  50 replies
  • Hot  47 replies
  • Hot  36 replies
  • On January 15, 2017
