PWK swap on 02 cr250
26 replies to this topic
  • Bentbars
Posted January 13, 2011 - 06:37 AM
I can't seem to find the info in a search so here i am
I just picked up a used keihin 38 pwk and the bike has a boysen rad valve and pc platinum pipe on it and i would like to get some base line jetting recommendations.
I have access to a bunch of keihin needles and it has a #7 slide in the carb.
1500- 3000 elevation
50-75 temps
Thanks for any help
  • Snipetracks
Posted January 13, 2011 - 10:23 AM
Read this thread. In the end I think he went with the 1999-2000 Honda CR250R JD jet kit.
http://www.thumperta...ht=new 06 cr250
  • Bentbars
Posted January 13, 2011 - 04:49 PM
I couldn't find any info in that tread about a 02 with a pwk.
Somebody out there have some info they would share?
  • ulmanb
Posted January 13, 2011 - 07:10 PM
I had installed the stock 2000 cr250 pwk into my 05, it had the stock 00 jetting I think. Anyways, it worked pretty well just like that. I think it was 45 pilot, 175 main, 3rd clip.
I later ended up going with a JD needle, 175 or 172 main, 45 pilot. Cant remember the color of the JD needle though. I followed the JD guidelines for the yz250 kit.
  • Bentbars
Posted January 13, 2011 - 08:32 PM
thanks for the reply.
Did you like the jd or the stock 2000 jetting?
Do you know what pwk needle the 2000 carb had in it?
  • RyJen
Posted January 14, 2011 - 02:23 AM
Did you buy a PWK from a YZ?
If so, start by buying the needle and jets for a 99-00 PWK from Honda. That will give you your base, and may work just fine for you.
  • ulmanb
Posted January 14, 2011 - 02:55 AM
the stock 2000 needle worked pretty well, I just happened to have a JD kit, so I tried it and like the JD needle a bit better and stayed with it until I installed a 36mm keihin instead.
  • Snipetracks
Posted January 14, 2011 - 05:20 AM
The PWK stock 2000 Needle is 715/289R.
  • Bentbars
Posted January 14, 2011 - 06:28 AM
I just pulled the needle out and i think it is off a 2000.
The numbers are all most impossible to read compared to the brass.
There are three stacked rows of numbers
A715
289R
can't read the other 2 rows even with a magnifying glass.
I,m going to put that carb on the 02 we are freshening up
and on my bike which is a 01 motor in put into a 02 frame i did buy new pwk from JD.
almost done with the swap and it looks amazing. the bike looks almost brand new.
Thanks for the reply's.
  • SubTexel
Posted January 14, 2011 - 07:29 AM
02-07 will benefit from the same jetting with a PWK swap (changed for your particular mods / altitude / weather of course). Same goes for the 01.
I ran the 289 needle (2000 CR needle) but I wasn't 100% happy with it, bought the JD kit and got what I was looking for (their needle was the ticket in my case).
With your 2000 CR needle something in the 175-178MJ and 50-52PJ will get you in the general ballpark (any smaller on the PJ and I lost bottom end from it being too lean). I think I had it on the 3rd / 2nd clip, and moved it around but like I said, just didn't do it for me with my riding / altitude / etc...
  • Fred ridin red 88
Posted February 26, 2011 - 06:03 PM
Will the 06 yz pwk work also on a 06 cr then
  • Phil Hannah
Posted February 27, 2011 - 06:14 AM
It will fit like a glove!
  • Fred ridin red 88
Posted February 27, 2011 - 06:30 PM
wil a 39mm pwk work
  • 01cr80
Posted February 27, 2011 - 06:45 PM
it may squeeze in but you will be taking alot away from your low end power and put it on top, if your fine with that go for it you still may have some trouble jetting though
  • caterpillar3512
Posted February 27, 2011 - 07:54 PM
Does anybody know if you can a 39mm pwk on a 2002-2003 cr 250
  • Fred ridin red 88
Posted February 28, 2011 - 09:40 AM
well my 38mm pwk is on the way and im goin to do some ridin in the mountains of west nc. Elevation is from 999 to about 2500 and the temps r supposed to b in the low 70s can anyone give me a quick ballpark im unsure whats in it at the moment but any info is appreciated.
  • Fred ridin red 88
Posted February 28, 2011 - 09:41 AM
should of specified for jetting lol
  • qwikz74
Posted March 05, 2011 - 01:49 PM
Not to resurrect an old thread but I just bought a 38mm Air Striker and this is what I was recomemded to use by a member on the ATM forum. Also did some research on my own and found people using very similar jetting with the Keihin.
Elevation 250-1000 ft
Temps 53-64 spring/fall and 71-95 summer
Main-172
Pilot-42
Air Screw-1.25-1.5 Turns Out
Needle-1370DKA- 2nd Clip (stock needle on 99 CR250)
Slide- #7
Float level-16mm
Edited by qwikz74, March 05, 2011 - 03:39 PM.
  • Bentbars
Posted March 05, 2011 - 07:32 PM
I would set the float level to 17.5. I find that 16mm pukes way to much fuel out the over flow with just a little off vert and bumps.Kinda shortens the mileage out of a tank of gas as well. If you ride the open all the time and have throttle
wide open you might need to have a higher level.
  • erik_94COBRA
Posted March 06, 2011 - 05:27 AM
On my '03 CR250 with a PWK from a '00 CR250, I'm running the following:
Main - 178
Pilot - 48
Air screw - 1.25 out
Needle - stock, 4th clip position in Fall/Winter/Spring (<70). Back to the 3rd for Summer.
Slide - #7 (stock for '00)
Float at 16mm.
With the same jetting and the 1370DKA on my '01 CR250, I had part throttle pinging through the 4th clip position so I switched back to the stock needle. It had really good power except for the pinging. Switched back to the stock needle (A715-289...) and it went away.
After I have my squish modified, I'll probably try the 1370DKA again.
Update: Tried the 1370DKA today at the track, with otherwise the above jetting. Ran really good in the 4th clip position. Probably would have ran a little better with in the 3rd clip position. May try that next time out.
Edited by erik_94COBRA, March 06, 2011 - 07:01 PM.
Error.
What would you honestly pay? by crdude
Dirt Bike   Make / Model Specific   Honda   Honda 2-Stroke
  • Hot  30 replies
2003 CR250 by asealy20
  • Hot  34 replies
Honda CR500AF Action Video by HeddleTown
  • 2 replies
Street Legal Two Strokes? by Yo_ITS_Yamaha
  • Hot  44 replies
2006 CR125 Rattling (Piston Slap?) by Will I Am
  • 23 replies
