Tire Pressure for 2002 TTR125L
5 replies to this topic
  • JayPak
Posted July 22, 2003 - 06:25 AM
Anyone happen to know what the tire pressure (psi) should be for a 2002 TTR125L?
Thanks!
  • aedwards07
Posted July 22, 2003 - 06:38 AM
15psi
  • Was_that_a_THUMP
Posted July 22, 2003 - 10:28 AM
make it 10 if you want to grip better :)
  • NEV YZ
Posted July 22, 2003 - 10:34 AM
yes 15 p.s.i. is a good all around pressure, if you ride in the rocks you may want to bump the front up to 16 or 17 p.s.i. so you don't pinch a tube. on the other side of the coin, you may want to run the rear at 12 or 13 p.s.i. in the sand.
  • One_Dollar
Posted July 23, 2003 - 01:22 AM
Like Nev YZ said, it depends on the terrain. If it's mostly real deep sandy trails like here in florida you want like around 10psi, if your in a rooted rocky trails you would go 15 or even 18psi.
In sandy trails a high tire pressure will give a tendancy for front wheel washout in turns, in rocky rooted sections a low tire pressure will bend rims.
  • Was_that_a_THUMP
Posted July 23, 2003 - 02:48 PM
I put 20 in my rear tire when I'm just riding around in a dusty field and practicing my racing starts cuz the backtire doesn't want to grip and it just spins
