Fresh Rebuild: Dies when applying throttle
7 replies to this topic
  • bhsballer76
Posted January 12, 2011 - 08:12 PM
I tried to start up my 06 yz450f today after a full bottom and top end rebuild. The bike fired up( and continues to do so each time I start it) quickly and idles fine.
Problem is it dies EVERY TIME i apply even the smallest amount of throttle. IF I just very slowly twist it, I can hear it start to slow down and it will die even before an 1/8 of throttle has been applied.
The carb was drained before I began the rebuild, so I think I can rule out clogged jets??
Also, it doesnt seem very responsive to the idle adjustment screw.
What would cause this? Its boggling my mind at this point:bonk:
  • roost666
Posted January 12, 2011 - 08:50 PM
have you connected the carb properly you may have an air leak
Posted January 13, 2011 - 07:29 AM
Not by the sound of things, no.
  • locomike
Posted January 13, 2011 - 07:01 PM
What he said.
Check your airbox boot seal to the rear of the carb.
  • bhsballer76
Posted January 13, 2011 - 07:10 PM
What he said.
I did have one hell of a time getting the seal on the back of the carb... would even a small air leak cause this to happen??? It just seems like the bike may run a little strange, but it wont run at all as soon as I being to apply throttle...
  • dirtdad733
Posted January 13, 2011 - 08:19 PM
are you sure you got the timeing right long shot but check the tps make sure its hooked up and has not been moved
  • locomike
Posted January 14, 2011 - 01:31 PM
After I replaced the subframe/airbox boot it wouldn't take throttle at all and idled poorly, to the point I kept increasing the idle speed to try to get it to accept throttle without the choke on. While the bike was idling, I finally reached down and grabbed the side of the airbox boot and gave it a strong tug/wiggle and the idle instantly climbed and it would rev normally. I turned the idle back down to normal and it ran perfect.
  • bhsballer76
Posted January 14, 2011 - 03:04 PM
thanks for the info...sounds exactly like my problems.
  • Hot  38 replies
  • 0 replies
  • 5 replies
  • On January 15, 2017
