WR450F + 09 YZ Cams + FMF 4.1 Megabomb + CP High Comp 13:1 + Vortex ignition - Dyno
5 replies to this topic
  • muddza
Posted January 12, 2011 - 06:26 PM
While recovering from an ACL reconstruction in my right knee I thought I'd have the motor rebuilt in the '08' WR with '09' YZ Cams, CP High Comp Piston 13:1, FMF 4.1 Megabomb full titanium system + Vortex X10 Ignition, then had it jetted to suit & dynoed.
View the dyno run
The end result.... MAP-0 on the vortex
Max Power - 50.08 hp @ 8500 rpm
Max Torque - 32.82 ft-lbs @ 7000 rpm
Jetting as follows
Main - #170
Pilot - #45
DSQ Needle - 3rd Clip
Fuel Screw - 1 1/4 turns out
More cosmetic mods to come!
  • Shred Jesse
Posted January 12, 2011 - 07:07 PM
Any chance we could get a higher resolution image? I'd like to see a dyno run from stock to compare to!
  • muddza
Posted January 12, 2011 - 07:13 PM
Here is the link to a higher resolution dyno image...
Think the stock WR puts out under 40hp without de-restricting???
The dyno shop had recently done a WR450F with a white bros full system + vortex Ignition with stock cams which had 45 Max hp. When compared to my graph I had a fatter curve all the way from when the throttle was cracked off the bottom :smirk:
  • Shred Jesse
Posted January 13, 2011 - 12:26 AM
Ahhh, now that looks like it definitely breathed some life into your bike!
  • muddza
Posted January 13, 2011 - 01:15 AM
yep sure did... more like a fire breathing monster!!! Ohhh and it's street legal here in AUS... but lets keep that on tha down lo hahahahha
  • muddza
Posted January 13, 2011 - 02:39 PM
They also compared my bike with a stock 2010 YZ which ran identical power curves but just had 2hp more in the over-rev...
