2007 YZ450F Top End Rebuild
16 replies to this topic
  • geshields
Posted January 09, 2011 - 07:47 PM
My bike is approaching 90 hours of practice and Race time and I feel like it is time for a new top end. The bike is getting slightly harder to start when it is cold for the first time of the day. I may need 6-8 kicks on the first start of the day. Once warmed up, it always starts 1st-2nd kick. I just checked all my valve clearances and they are all within spec.
Intake 1 - .10
Intake 2 - .10
Intake 3 - .15
Exhaust 1 - .20
Exhaust 2 - .20
I cannot find my paperwork where I wrote down the baseline specs when it was new.
I always change the oil at least every 6 hours, oil filter change every other oil change, and a clean newly oiled air filter every ride day.
I know I need to change the cam chain and figured while I have it apart, I might as well do anything else I need to while in there. Replace piston and rings?
I am leaning towards a CP piston and upping the compression to 13.5:1 Good choice?
  • ForsheeMS
Posted January 10, 2011 - 02:13 PM
At 90 hours a new piston and rings would be a good idea. The CP 13.5 is a good piston. I would also replace the valve springs (they're cheap) and stick some new valve stem seals in there while it's apart. From there it should be good for another 90 hours.
  • brentn
Posted January 10, 2011 - 05:17 PM
What's a good way to remove valve stem seals without damaging the head?
Posted January 10, 2011 - 06:30 PM
Exactly how do you normally remove valve seals??
  • brentn
Posted January 10, 2011 - 08:14 PM
I never have, I'm curious how this is done cause when I think about how I might attempt to do so I would probably damage the head.
Posted January 10, 2011 - 10:07 PM
Remove the valve springs, remove old seals, put the new ones on. No hammers or crow bars involved.
  • fishkiller
Posted January 11, 2011 - 06:53 AM
I have almost 90 hours on my 09'. Everything said above would apply to me as well, maint. ride condtions and so on.
Already recieved my OEM piston, rings, timing chain, wrist pin and circlips. Did not even think about doing my springs or seals. What is yalls opinion on this? SHould I do it now or not worry about it? Thanks.
DJ
  • SparksXR426
Posted January 11, 2011 - 07:11 AM
I did my 08 at 100hrs. All OEM, did the valve seals but not the springs. Cant see the springs being a problem yet, but the doing the seals make sense while its apart.
Posted January 11, 2011 - 07:42 AM
YZF valve springs are ordinarily quite reliable, but they are also too inexpensive not to replace at $25 a set. At that price, the potential trouble they could cause just isn't worth taking the risk.
  • fishkiller
Posted January 11, 2011 - 07:48 AM
Thanks again Team Thumpertalk! WIll order seals and springs now. Thanks.
  • ForsheeMS
Posted January 11, 2011 - 07:50 AM
Once the valves and springs have been removed reach in with a pair of needle nose pliers and pull the seals off of the valve guides.
The springs will sack out over time and begin to lose pressure. The stock springs are relatively cheap compared to what you have spent already so there is no good reason not to replace them while you are already this far in.
As far as the valve stem seals go, anytime I remove the valves the seals get replaced. Like the springs they too are dirt cheap and much easier to do now than have to pull everything back apart to replace one later.
While the valves are out is also a perfect time to remove carbon from the combustion chamber, valves, and exhaust ports plus there is no way to completely inspect the valves, seats, and guides without removing the valves.
Posted January 11, 2011 - 08:56 AM
I knew that, of course, but I was curious as to what kind of damage he might be concerned about doing to the head through whatever process he normally used, or imagined being used. Struck me as a very odd question, somehow. :smirk:
  • brentn
Posted January 11, 2011 - 12:23 PM
I thought they were pressed in! :smirk:
Had no idea they just slid out... Going to have to do some more reading. Thx.
Posted January 11, 2011 - 01:11 PM
I think you're thinking of the valve guides. The seals are easy.
  • brentn
Posted January 11, 2011 - 02:51 PM
I didn't know they were two parts, thought the valve guide was the seal... Thx for the clarification
  • homernukem
Posted November 13, 2011 - 08:41 PM
Where can you buy a new set of valve springs for $25 for a complete set?
Posted November 14, 2011 - 07:51 AM
That price quote is a year old. TT OEM currently sells all five for $37.72
  • 0 replies
  • Hot  50 replies
Motocross
  • Hot  491 replies
  • 9 replies
  • Hot  47 replies
