fork oil amount- 2006 wr450
2 replies to this topic
  • bikeslut
Posted January 08, 2011 - 08:57 AM
I searched... really I did
Shop says: 21.89 fluid ounces in each fork leg... when I drained it, it sure didn't seem like 21 ounces... anybody offer confirmation?
also- once the oil is in, I collapse the fork, with spring out, and it should be ( ) from the top?
I am getting a manual, but hoping to wrap this up soon
  • tribalbc
Posted January 08, 2011 - 11:12 AM
You can find free downloads of the manual in the sticky's :smirk:
Fork oil height is done with spring removed, fork collapsed and damper rod fully down. Measured from top. Will take around 600ml per fork depending on oil height.
  • Dan_Lorenze
Posted January 10, 2011 - 07:41 AM
5" from the top, collapsed with the spring out. Make sure you get all of the air out.
