frame
5 replies to this topic
  • papa cokes
Posted January 05, 2011 - 04:55 PM
need to know if i can use a 2007 yz 450 frame to replace my 2007 wr 450 frame? i am going to use everything else off the wr
  • matt4x4
Posted January 06, 2011 - 05:17 AM
yup same frame
  • 123BigcoopDawg576
Posted January 06, 2011 - 07:29 AM
yup same frame
uh...not quite....
you will need the yz sub frame and air box as the mounting points are different on the wr frame (due to the air box door)
Posted January 06, 2011 - 10:10 AM
The rest of the main frame has several differences, as well, mostly somewhat minor. The skid plate mounts are different, as are the mounting bosses for a few other things. I believe there are some subtle differences in the geometry as well.
  • papa cokes
Posted January 06, 2011 - 04:53 PM
i just need info on the frame going to use everything off the wr
  • 123BigcoopDawg576
Posted January 06, 2011 - 06:07 PM
well then the two above posts your last one should help you...
