HELP...Burning Lots of Oil YZ450
3 replies to this topic
  • cbesing
Posted January 04, 2011 - 06:15 AM
Here is the History..
-New piston/rings 40 hours ago..Checked valves and they were in spec.
-Last trip burned 600CC of oil in one 45 min ride
-Checked valves...very loose both exhaust and intake
-Oil black/metallic after oil change and a warm-up on the stand
Also, I seem to go trough timing chains every 50 hrs or so...I know its time to change because the cam jumps teeth and it wont start.
Any Ideas...
Thanks
Chris
  • cbesing
Posted January 04, 2011 - 06:16 AM
BTW, its a 07 YZ450F
Posted January 04, 2011 - 06:58 AM
Sounds like the cylinder plating has failed.
As to the cam chain, it shouldn't be jumping teeth each 50 hours. Replace the tensioner and consider using a different oil or changing it more frequently. You may also want to check the cam caps for signs of seizure.
  • tech24
Posted January 04, 2011 - 07:01 AM
you could confirm it with a leakage tester if you have access to one, however can't think of anything else that would cause that kind of oil consumtion (something cylinder related that is).
Is it smoking? I would imagine so.
