06 yz450f backfire Help!
8 replies to this topic
  • IamRooster151
Posted January 02, 2011 - 03:02 PM
my 06 450f backfires quite a bit (more than usual) carb was clean and the valves are clean and has fresh gas, dont know what the problem is. help me identify this problem and ho to fix it
  • curtis515s
Posted January 02, 2011 - 06:38 PM
Your stock pilot jet is a 42. Replace it with a 45 and almost all of the popping will go away. Some run them even richer than that but a little decel popping is normal. The 45 pilot made my 06' much better. It's the best $ 5.00 you'll spend on your bike.
Edited by curtis515s, January 06, 2011 - 08:16 AM.
  • rasta
Posted January 03, 2011 - 01:39 AM
did you check the valve clearance? maybe adjust the mixture screw as well, none of my yz's would back fire on decell unless valves were off or mixture screw was off setting
  • Mike Martel
Posted January 04, 2011 - 06:53 PM
jd jet kit did the trick on my yz450f.
  • ForsheeMS
Posted January 04, 2011 - 07:28 PM
I think Curtis hit it. The pilot is a little lean, especially with the colder temps now. Make sure you don't have an exhaust leak anywhere as that will cause the popping too but the pilot is most likely your problem.
  • hillclimbguy
Posted January 05, 2011 - 11:46 PM
Some good advice. I did the same thing on mine. Richen the pilot!
  • alliance52
Posted January 08, 2011 - 12:43 AM
I had a truck with a straight 6 motor on LPG it use to backfire really bad if the timing was retarded. Just a thought hope this helps.
  • racertodd
Posted January 08, 2011 - 03:05 AM
I had some backfire issues with my 06 yz250f as it ended up the hotstart cable didnt have enought slack in it. It wouldnt close all the way. Maybe this is the problem could be not enought slack or possibly not moving free and maybe the hot start is opened a little. Just a thought hope you get it figure out
  • 03cr125r
Posted April 02, 2011 - 04:03 PM
im wondering if a lean pilot would cause it to not idle
  • 0 replies
  • Hot  38 replies
  • Hot  36 replies
