Pro Circuit CR500 2001 Jetting Chart, need explaining please.
8 replies to this topic
  • AndyMx
Posted December 29, 2010 - 11:36 PM
G'day guys, i'm wondering if someone can explain to me the CR500 jetting specs i obtained from the Pro Circuit website that i have highlighted?
Are the details listed beside CR500 the stock jetting specs? and the details beside Pro Circuit the jetting specs if a pro circuit pipe is applied to the bike?
What does STD mean? Standard?
What does POS mean?
and which screw are they referring to for the 1 1/2?
Please forgive my ignorance, i have never gotten into the jetting side of things.
Thanks in advance.
Andy.
  • yathump
Posted December 30, 2010 - 02:38 AM
Yes
Correct
What does POS mean?
Position of the clip
Airscrew
Thanks in advance.
Andy.
I answered inside the quote in bold
This is for the CR5 with the stock PJ carb on it, Service Honda mounts a 39.5 PWK carb on their bikes so jetting/ jet numbers will be different
  • HrcRacing
Posted December 30, 2010 - 12:49 PM
Air screw (brass straight slot) location:
  • jbird710
Posted December 31, 2010 - 11:05 AM
Position of the clip (needle clip) see diagram below:
  • riles
Posted December 31, 2010 - 03:21 PM
Blue haze,
FWIW, I've just finished rejetting a 2000 stock 500 (fmf gnarly, fresh top end and the head shaved for a bit more compression)
I tried the fmf jetting specs but got pinging at 1/4 throttle and a slightly lean feel.
I went to 58 pilot, position 4 standard needle and a 172 main.
This was better all around and what I'm going to to ride with for a while.
This is for trail riding, 70f, sea level, premium fuel,40:1.
500s are new to me so others on this forum are more experienced but I share my specs as you in australia too.
  • AndyMx
Posted December 31, 2010 - 09:49 PM
cool thanks for some great info guys, really appreciate it. And Riles your info will help heaps seeing as we are on the same continent.
  • Keith Z
Posted January 02, 2011 - 05:02 AM
You should use the chart as a GUIDE only. I live on the east coast of the US and found that the jetting recommendations are too rich for my area. We have a lot of humidity which makes the need to run leaner. You need to experiment for the best results. Good luck.
  • LovingOffroadPain
Posted June 25, 2014 - 12:50 PM
Blue haze,
Now that the 500 isn't so new, how do you like it??
  • frdbtr
Posted June 26, 2014 - 06:55 AM
Holy old thread batman.
CR125 High Revving on Start Up by Will I Am
Dirt Bike   Make / Model Specific   Honda   Honda 2-Stroke
  • Hot  28 replies
2006 CR125 Startup Help by Will I Am
  • 13 replies
250 2 stroke vs 125 2 stroke by pnitro4
  • Hot  63 replies
cr125 build questions by austin_honda
  • 7 replies
CR125 Carb Cleaning Help? by Will I Am
  • 6 replies
