My sled keeps bogging at 4000-5000 rpm and when u play with the throttle it finally comes out of it it doesn't do it when it's cold but once the engine heats up it starts bogging. It's so bad it won't even move. Just had the sled rebuilt Had the carb cleaned fuel tank lines flushed . The plugs are black but not soaked I guess my next plan would be to make it bog and hold it then kill it to check the plug color
1997 Indy 500 bogging
Started by
tvalliere220
, Dec 29 2010 03:43 AM
7 replies to this topic
Posted 03 January 2011 - 01:28 PM
First thing I would check is the condition of the choke plungers, there's a rubber ring on the bottom of them and if they are old and brittle (ethonal fuels are really hard on them) they will leak fuel by and make your mixture really rich. Next thing I'd check would be the coils.
Posted 13 January 2011 - 01:43 PM
Ok so I now know it has nothing to do with jetting it happens when I turn something starts binding up my track is adjusted right and my clutches are clean it squeaks every now and again but that's it
Posted 13 January 2011 - 07:44 PM
Drive shaft bearing on the clutch side would be my first suspect in that case. Loosen up the track and see if you can wiggle the track drive shaft.
Posted 14 January 2011 - 03:08 AM
By loosen up the track do u mean the entire skid and everything or just the track itself
Posted 14 January 2011 - 11:49 PM
just the track so it takes tension off the drive shaft so you can tell if there's movement in the bearing or not.
Posted 18 January 2011 - 03:12 AM
I checked that and it was good there was a bad roller in the clutch
Posted 12 March 2013 - 12:27 AM
This happened to my 86 indy 600 triple. Go into the carbs. Clean them. Check float adjustments and make sure they are set properly. Then check the float needles and make sure they are all in good condition and sealing properly. After that if it doesn't work its all carb tuning. Essentially (if my prediction is correct) the sled is getting too much fuel. This problem stumped me for months and I had my mechanic look at it. He made me feel pretty stupid haha. Anyways try what i said and if that doesn't work I hope you can find a solution!
Polaris 800 PRO- RMK 155 (2012) |
Polaris XLT SP Xtra (1994) |
Polaris 900 RMK (2006) |
KTM 525 XC-W (2007) |
Polaris XLT Touring 1999Polaris XLT Touring 1999 |
View Garage
Follow us:
